Question about Refrigerators
I HAVE A BAR LIGHT UP ON THE DISPLAY BUT THE UNIT IS NOT WORKING, JUST THE LIGHTS INSIDE?
    New Friend:
  • 49 Answers
Demo mode? Consult your owners manual.
Posted on Dec 12, 2014
Odometer display light not working
For most vehicles you need to remove the dash (usually the face only) and then take out the Main Instrument Unit "MIU" and replace necessary bulbs.
Jan 08, 2014 | ACDelco 2002 AC DELCO-FW293 Olds Intrigue...
No key's work. Display and inside light is working
The Keypad is either faulty, or disconnected. Open the case, and remove the screws, holding the outer shell on. Inside, there should be a small board that covers the Keypad. Check to see if there is a ribbon cable, or some other type of connection going from the board to another part of the microwave. If all of the wires are connected, then you will probably need to replace the keypad.
Jan 26, 2008 | LG LMVM1955 Microwave Oven
Kenmore refrigerator model 795.78312.800 not working no display
If you have no lights on the inside of the unit and no display first verify you have power to that outlet. If you have power to the unit then you have a blown fuse on the main board. Part number: EBR41531305 The main board is on the back of the unit.
Mar 14, 2013 | Refrigerators
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
2 vertical bars on tv screen
OPEN THE TV AND BLOW IT OUT ..THOSE BARS ARE THE EFFECT OF DUST INSIDE THE UNIT CLEAN OUT AS WELL AS YOU CAN AND THAT SHOULD FIX
YOUR PROBLEM
Feb 06, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Plugged it in and it makes a clicking sound it won't do anything
nothing else ie no display, no lights if so dead main board no be economical for repair
if it has display ok then there is paper stuck, take out back door, check there..
also with the power off, check inside right up inside against far left and right walls of unit, paper gets stuck inside and then the bit that moves up and down along the silver bar(carriage and print head) slams the paper up against the wall. You need to reach in with two fingers and get it.
Nov 03, 2009 | Brother MFC 210C All-In-One InkJet Printer
Control Panel Display
May be wiring ....at switch...reversed...polarity...or control replace..
Mar 22, 2008 | Jenn-Air JXT8136ADS Kitchen Hood
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
