Question about Vehicle Parts & Accessories
I have a python car starter and it starts the car but immediately shuts it off and keeps repeating
    New Friend:
  • 49 Answers
Do you have a chip in your key? Sounds like it was not installed correctly. If newer car and your key has a chip then it will not start it unless you have your key in ignition. You can test this by leaving your key near the ignition or in the ignition and see if you can start it with the remote. If it works then There is a way around this but its very involved with the vehicles wiring harness and anti theft features. I recommend asking the manufacturer. But if you insist on doing yourself at least get a repair manual so you can have the wiring diagrams and trace the circuit. Good luck. Hope this helps.
Posted on Dec 12, 2014
4 Suggested Answers
slick42371
  • 42 Answers
SOURCE: Python 1600 XP Remote Starter my
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
Posted on Feb 02, 2011
  • 111 Answers
SOURCE: I have a Python car starter and it hasn't been
Check out this Guides > python 1400xp remote starter
And
> My Remote Car Starter Stopped Working DON PANIC
Posted on May 05, 2014
  • 111 Answers
SOURCE: I have a Python car starter and when I try to
Check out this site for help > My Remote Car Starter Stopped Working DON PANIC
Python alarm
The truck thinks you are trying to steel it. It needs to be reset ypu will need tocontack python and they will help you rest it.
Aug 14, 2014 | Cars & Trucks
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
I have the Python CE0890 on my 1999 Dodge Durango, The alarm goes off without explanation and the car turns on. The light on the remote flashes constantly then goes dead. It will not allow us to open,...
You have a remote brain that's gone bad. Locate an aftermarket black book under the driver's side dash. Unplug the harness' connecting into that box. Depending on the install, you may not need to go further. If the system has remote start you may need to locate the starter wire and reconnect it.
Dec 09, 2017 | 426P 460HP Security System - 426P
I recently installed a python 872 on my 2002 maxima. Now everytime i use the remote start and open the trunk the car shuts off and restarts in about 10 seconds. I had other dei alarms and never had that...
It's possible that the installer has the engine monitoring option programmed for voltage and, the unit sees a drop in voltage when operating the trunk...causing the remote starter to shut down. If so, try programming the unit for tachless instead or, hook up the tach wire.
Jun 10, 2011 | 872 Responder LE Security Remote Start
Python 1600 XP Remote Starter my car starts at 1 pm daily automatically. How do I remove this timer on this remote starter
Dec 23, 2010 | 1600XP Security/Remote Start System
I got a 95 chrysler seabring and it wont start, I took it to chysler and they cant find the problem, someone said it could be the python car starter, how can I get it off or over ride it
under the dash there is a black/red wire, this is your starter wire, there might be a starter kill relay line line with this wire, unplug the relay and run a jumper wire from pin 30 to pin 87, this will bypass the relay
Feb 22, 2010 | 1401 Remote Start/Keyless Entry System
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
