Question about Water Water Heaters
I need internal wiring schematics for titan n120 tankles water heater. need to make sure i wired thermostat correctly
Where is the reset button on a titan flomaster
were can I get repair service now Titan Scr 2 N120,In Spring Hill,Fl
May 15, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Wiring schematic for a upper thermostat
Jan 2013
1) Copy following links for wiring upper thermostat:
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
2) Thermostat must sit flat against tank wall to read correct temperature, and entire opening must be covered with insulation so cool room temperature will not interfere with temperature reading.
Be sure to put cover back on side of tank for electrical safety, and to prevent any possible fire caused by melted parts and overheating.
3) Tighten wires very tight under screw plate, and make sure only copper wire is used, and all wires under plate are same gauge, do not mix stranded wire and solid wire or stranded will become loose.
Only copper under the screw plate and cut back insulation so no insulation gets under screw plate.
http://waterheatertimer.org/images/Burned-thermostat5-143.jpg
4) Add comment and say what you are doing
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 23, 2013 | Rheem Water Heaters
Need a wiring schematic
Copy following link for tank-type electric water heater wiring:
For tankless electric:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
For tankless gas, hybrid, combo, boiler, indirect, solar, heat pump, etc then re-post question with specific brand and model number for possible help
For switches, timers, lights etc:
http://waterheatertimer.org/How-to-wire-switches.html
Oct 31, 2012 | Water Heaters
I have a reliance electric hotwater tank and the lower left side of the thermostat is totally melted, what is the cause of this?
An internal short in the wiring of the thermostat. It is not as common an occurrence as it use to be, but it still happens.
I would check your breaker panel and make sure the water heater's breakers are the correct size for your unit.
Sep 15, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Titan-SCR2 N-120, water heater, need schematics
I have taken pictures and produced a wiring diagram for this model
Jan 23, 2009 | Water Heaters
Water Heaters Logo
141 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
