Question about Toshiba Computers & Internet
I can hardly hear my cd's now I was ok before
I have tried to improve my sound by turning volume up to 100 but it is still to soft. I have a Toshiba PASCAL model ooxoojen
    Top Expert:
  • Toshiba Master
  • 23,109 Answers
Check the settings of the virtual mixer.
Posted on Dec 12, 2014
We can't get the volume loud enough to hear when we record to a CD
This unit is a pro unit that makes use of XLR type inputs. These are typically at +4 dBm signal level not that of the -10 from RCA type mixing boards. So what you need to do is take the RCA outputs from your source and hook them to a IHF or unbalanced to Balanced converter and they are available from MCM Electronics. This device here should take care of the problem.
http://www.mcmelectronics.com/product/555-8485
Oct 06, 2012 | Tascam Cd-rw900sl Cd Recorder/player
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
Hello,can any one help.i have a technics su-x955 amp that has has finally after mant years has packed up.when i power up i hear the usual click sound in the amp and all the other separates fire into...
If you hear something faint this would not be a fuse issue.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the
amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2
volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control
or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or
'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like
Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 08, 2011 | Audio Players & Recorders
My 2001 330ci has the Harmon Kardon sound system. However, when I run the system at high volume for about 5 minutes, the front speakers start cutting in and out. It doesn't seem like a speaker is blown,...
Thermal issue is shutting down amps till temps moderate. You must be driving your system too hard. And check out your tone control settings especially the bass. Every 3 db boost forces amp to double power at that frequency so if you are already blasting at 100 watts, a 3 db boost will compel amp to put out 200 watts, etc. Very easy to overdrive and overheat amp. You might want to try blowing air over output stages to improve cooling at high volume levels.
You are lucky that you have good protection circuits - otherwise by now you would have blown the output stages.
May 08, 2017 | 2001 BMW 330
Volume will just blast real loud
If you have a remote control , unplug the lead from the volume control (at the back of the machine) and instead of it plugging into the Inrfa Red control unit in the base of the cabinet, plug it straight into the amp volume input.
There has been problems with the remote that does what you are suggesting so this will prove the point.
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
I just bought the Linksys CIT310 IP Wireless phone
Hi
On the phone menu, select "Base Settings" then click on "ringer type". The volume there has 1 - 5, try increasing the volume.
Jul 29, 2008 | Linksys CIT310 IP Wireless Phone
Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Oct 11, 2007 | Televison & Video
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
