I have no audio on two cable TV channels. Is it possible to mute audio on specific cable channel numbers? And if so, how can I get the audio back?
I've scrolled through the setup menus by remote, and I've looked at the manual online, but so far have not found a fix. Should I try re-calibrating the cable/channel selections by running auto-setup? But if that doesn't work, is there a way to un-mute a specific channel number?
  • Neil McArthur
    Neil McArthur Dec 12, 2014
    I found the fix. While on the channel with no audio, I pressed the "Audio" button on the bottom left of the remote control, then toggled to "Stereo" - specfic channels had been set to "SAP" by mistake and prevented the audio from
  • Neil McArthur
    working. Choosing "Stereo" or "Mono" instead of "SAP" restored the channel audio.
You cannot normally mute just certain channels. It's usually all or none. Do you subscribe to the channels that have no sound?
Dec 12, 2014 | Panasonic PV-C2060 Combo
I have no audio on two TV channels (Disney and Nickelodeon). Is it possible to mute audio on individual channels? I am guessing this happened by mistake.
Have you checked your parental control settings? That would be about the only way I know of the to mute certain channels. But if your locked out a channels there would normally be no video either.
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
Apr 24, 2017 | Samsung SyncMaster Televison & Video
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
Channels 3, 4, 5, and 7 are mute. The mute button has no effect.
there should be an audio section of your tv
Go through each of your setting s and be sure nothing was changed. goto setup and reset to factory settings. your TV will do something funky and powercycle.
THAT should fix your problem.
if not, is your cable service through your VCR? if so, remove the vcr altogether and connect your cable services directly. All should now be a go.
Aug 26, 2009 | Element Electronics Televison & Video
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
No audio or video
If you can see the channel number as well as the volume setting when you press on the appropriate buttons on the remote, then it would seem that what happened is that your TV went into muting (video and audio). This can only be brought about if the TV is not receiving any signal from your cable or aerial. This is a built-in feature. Another possibility is that the tuner section of the TV has some issues. To determine whether cable or tuner, pls try installing a known operational VCR and play a good tape. Connect the RF OUT of the VCR to the CABLE/ANT IN of the TV. Select channel 3 or 4 and should you be able to watch the tap video, then you have just confirmed that it is your cable (or aerial). If on the other hand there is likewise no display on either 3 or 4, then you have just confirmed that somethings needs to be done internally in the tuner section.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Feb 05, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Help
This is possible a number of ways. Depending on the type of TV you have, it may have audio out on the back of the TV. This will be two jacks that are RED and WHITE, and it should be labeled "TV OUT" or "OUT". Use an RCA audio cable and connect these two jacks to the TV jacks of the same colors on your surround sound unit. If your TV does NOT have audio out jacks, you can still accomplish this by use of a VCR. Just run your main TV input [coaxial cable from antenna or cable/dish] into the VCR, and then out to your TV as normal. Leave your TV on channel 3 [or 4, or whichever channel the VCR uses]. If you're using a regular antenna, you can switch channels on the VCR. If you're using cable, you should be able to just change channels on the cable box. This will give you surround sound from an older TV without audio outs. But most larger and newer TVs have an audio out jack on the back. Hope this helps!
Sep 07, 2007 | Apex Digital HT-150 System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
