Display saying f-12 - Washing Machines
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
I set the date right but it says the wrong day
Is the Year right? If you are using 12 hour display the watch maybe 12 hours ahead or 12 hour back.
Oct 07, 2013 | Casio G-Shock GW300CA-1V Wrist Watch
How do you change the time on the NorstarTalk 180?
To set the time on the startalk 180: enter feature 984
the display should say log:
enter 1020000 and press ok
display should say <date>
press next if ok or chng if not
display should say enter hhmm:
enter time in 12 hour format
display should say retry am pm
press applicable key
press next then Rls
Feb 04, 2011 | NorStar Startalk Flash 2 Phone
Coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Feb 01, 2010 | Watches
Just need to reset the time on the main console norstar startalk 180 - manual doesnt have set up instructions
press next then Rls
Dec 10, 2009 | NorStar Startalk Flash 2 Phone
Old Startalk A voice mail and date and time does not match telephone system. Any ideas
enter feature 984
press next then Rls
Oct 07, 2009 | NorStar Startalk Flash 2 Phone
How do i change from military time on a insta-set alarm model 40009?
This may or may not work. The 40009 and 40010 are almost identical. The 40009 doesn't mention military time and the 40010 does, so you might want to what the manual says. 40010 manual and 40009 manual. According the 40010 manual, is says:
Displaying the12/24 hour, Date, Month and Year:
Display the 12/24 hour by hold the "+" button for 2 seconds. To display the date, month and year by press the "-" button, the year appears and then if pressed again, the month and date (eg. “12 31” means Dec 31) appears.
So maybe that will do. I have a 40010, but my manual is different from the one on the website. Its DST button and not Alarm Set button to change the time. So maybe try holding down different buttons for a couple of second see if one lets you change it between 12 and 24 hour. Good luck, hope this helps.
Mar 16, 2009 | Equity Time USA Insta-Set 44200 Clock...
My display says turn power to printer on
hi just try this reset code through to nvm 776-063.
Jan 22, 2009 | Xerox DocuColor 12 Printer
Too few arguments appeat when turn on the HP 48gx calculator
This calculator uses RPN (reverse polish notation) not algebraic notation.
If say you want to calculate 12+13, you proceed as follows
12 [ENTER] 13 + : the claculator displays 25
Similarly
12 [ENTER] 13 x : displays 156
Also if you use a function like sinus or cosinus
12 [ENTER] cos displays the value (depending on the angle unit you are using).
I think you need to read a little more on the RPN before you get accustomed to this way of doing thing. The best reference is your calculator Getting started manual.
Hope it helps.
Jan 18, 2009 | HP 48gx Calculator
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
