Question about Toshiba Computers & Internet
The sound on my Toshiba laptop is going cant hardly hear it
Have tried putting sound up to 100 but still is to quiet
    Top Expert:
  • Toshiba Master
  • 22,787 Answers
Virtual mixer setting?
Posted on Dec 12, 2014
Toshiba laptop wont boot correctly. Upon start up it flashes blue screen. Does not recognize optical drive to try to fix windows 8 or reinstall windows 8.1.
Sounds like the hard drive has an issue. Do you hear a very faint clicking sound when it tries to boot up? put your ear near the front of the laptop, bottom of keyboard area and listen for a clicking sound. if you hear a click click click click sound repeating continuously, its a failing hard drive. If you hear ths sound, you will need to buy a replacement hard drive. Replacing it is easy. Turn your laptop upside down and look for the small door that houses your hd. Unscrew the door and take hard drive out. Now you take this hard drive to Staples and ask them for a replacement. Once you know what you need, whether Sata or IDE hard drive, you can buy a replacement cheaply on eBay or buy it from any computer store. pop the hard drive back in and then you should be able to install a new operating system on the laptop. If you do not hear a clicking sound, then you may have a corrupted windows boot. Have you tried booting in safe mode? as you turn the power on, hold down the f8 button. You will get a screen asking if you want to boot in safe mode. Select, safe mode with networking. If it boots normally in safe mode, you can then put in your windows cd and do a repair. If you cannot boot into safe mode, and you have tried replacing hard drive, but cd/dvd is still not working, then you may need o take it in or diagnostics. You can buy very cheaply on eBay, a connector that will allow you to connect your hard drive to another computer via USB. This will allow you to test the hard drive and also possibly get data of of it, provided the hard drive is not too badly damaged. I hope this helps.. Please ask any questions you might have.
Oct 22, 2013 | Computers & Internet
Toshiba E205 laptop HDD is very busy/noisy. Keeps spinning up and then going quiet then spinning up again. I have checked to see if there is anything running in the background but it seems on the...
Hi try these steps:
1., run msconfig and remove the unecessary programs from autostart
2., download ccleaner (from here http://www.piriform.com/) and remove uneccessary files and clean the registry
3., download defraggler and finally use it to defragment the disk
At first I'm sure this does not sound like a serious solution but beleive me usually little things add up and drive you HDD nuts.
Feb 27, 2011 | Toshiba Computers & Internet
Hi i have a toshiba portege r-100 that when you put power to it with or without the battrey and turn it on you get the first four lights come on so there is power but all you get is a blank screen
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to
troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like Crucial.com
Oct 23, 2010 | Toshiba Portege R100 Notebook
I CANT GET ANY AUDIO SOUND ? HOW CAN I INSTALL SOUND DRIVE?I CAN SEE PICTURES IN MY LAPTOP BUT CANNOT HEAR ANY VOICE. MODEL NO. OF MY LAPTOP IS PSLB0E-02D01HAR SATELITE L300-129 SYSTEM UNIT, TOSHIBA
check that the volume control is not muted by going to control panel -- audio -- volume control and untick the mute button.
Otherwise try to reload the sound driver in control panel -- audio -- advanced - update driver
Hope this helps. It is hard to give exact intructions as you have not provided the details of your windows version.
Please rate the solution to help fixya serve you better in future.
Oct 15, 2010 | Toshiba Satellite Pro L300 Notebook
Hello .. Thank you very much . I was playing a music with my laptop and i tried to connect a ear pin for the speaker and all of a sudden the sound went off so you cant hear any sound . when ever i connect...
Plugging-in a set of headphones to the "audio-out" port *SHOULD* cause the internal speakers to become QUIET.
Unplug the headphones, to make the speakers work.
Sep 17, 2010 | Gateway 450ROG Notebook
Cant hear sound on labtop
There is a volume control knob on the notebook itself.....sheck to see if this is not set to minimum...
keep me posted
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite Notebook starts with black screen
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Acer Aspire 5100 Notebook
No Display, no audio, no power up sounds.
Sounds like a hardware failure because your not even reaching post. which means that its not software. i would take out the ram and hard drive. and then putting them back in. if that didn't do anything than I'm going to say you've probably got a dead mother board.
Aug 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
