Question about Hotpoint Dryers
What is a f12 fault
Aquarius vtd60
  • 32 Answers
F01 - Short circuit motor triac*
F02 - Motor jammed or fan blocked*
F03 - Front thermistor open/short circuit*
F04 - No pump piloting*
F05 - No feedback from the pump*
F08 - Static heater relay with contact welded closed*
F09 - Eeprom is not programmed or not functioning*
F10 - Common of heater open or one shot open*
F11 - No pump connection*
F12 - Communication error between board*
F13 - Rear thermistor open/short circuit*
F15 - Dynamic heater relay with contact welded closed*
F17 - Master relay welded closed* - See more at: http://www.hotpointservice.ie/help-and-advice/error-codes/#sthash.nR8Jb1cP.dpuf
Posted on Dec 18, 2014
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
What is a f12 fault on hotpoint dryer vtd60
Hi David,
F14 - A fault with the water heating has occurred*
Here is the link for the entire list of fault codes.
Fare. Well.
Dec 12, 2014 | Hotpoint Dryers
I have a Hotpoint Aquarius Tumble Dryer VTD60, but drum will not turn!! Any suggestions.?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 07, 2011 | Dryers
Aquarius WD 640 showing F- 12 what does this mean
F12 means a communication error between boards.
Check all connections to and from boards.
Hope this helps.
Jan 14, 2010 | Hotpoint Aquarius WD640 Front Load...
F12
Error code F12 is indicating that there is a communication problem between boards.
Check all connections on wiring and modules,
Hope this helps.
Dec 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wd440 showing f12 error code how can i fix it
F12 - Communication error a thing to try is resetting the machine to do this turn machine off at plug for 5 mins then back on and start a cycle and see if it happens again. hope this helps.
Nov 08, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Display saying f-10
Heater or thermostat faulty, probably thermostat, there are 2 of them, replace both.
Nov 17, 2008 | Hotpoint Dryers
Dryers Logo
208 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
