Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I believe that I have a HV problem but need some direction? Initial problem was smell and a pop noise resulting in three LED power on blinks with a squeal.
After numerous efforts to repair I still have three blinks and squeal is gone. The following parts have been replaced: CP114, CP120, CP130, flyback 259296, HOT C5588, DL201, CP049, CP050, CP019, CP012, CP113 and RP050. CP150, DL012, CP010 were removed and checked OK. Voltage at BP010 was about 330vDC. HV wire from flyback removed at splitter with no change. BA010 removed with no change. I recently asked a question about whether there is a red LED when set is in standby. I do not have the red LED. I am going back to the beginning of the troubleshooting and service manuals. I am a novice and I am enjoying this experience in solving this puzzle. Thank you in advance for any help.
  • 273 Answers
You could have a bad flyback usually they will make a sort of a hiss as there is a short internal and even the after market replacement flybacks can be new and defective .. or loss of horizontal drive . also the two chemical ribbons that jumper over from the signal board to the smps /deflection board the white ribbon connectors can cause problems also if you have the black one's there probably alright . or a shorted crt could send it into a shutdown . there are a few things to check and it appears your on the right track you have changed the caps on the deflection pwr board . let me know how it goes please
Posted on Dec 13, 2014
My sony did the same thing and worked fine after replacing the bulb. A pop sounds followed by a squeal is what I heard during and after the bulb blowing out. I hope this helps. And the red light flashed similarly.
Dec 12, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
My PT-50LC13's LAMP and TEMP light blinks 4 times and POWER light blinks 8 times continuously with 2 second intervals. I replace TY-LA1000 and FBL12G12L2CS Fan, but didn't fix the problem. Can anyone tell...
Listen carefully to the TV after the relays click. If there is a mechanical ticking or snapping noise after power On, replace the lamp because HV is present (causing the ticking). If there is no ticking sound, replace the ballast. You can confirm this by using the LED blinking pattern to localize the problem. refer to Service Manual or technical guide on the panasonic website for more help diagnosing LED patterns
May 01, 2011 | Televison & Video
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Powered on and geting off. No display front led is blinking 4 times.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
Apr 29, 2009 | Televison & Video
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDF- 42WE655 Blinks 6 times No picture or sound
was there a smell? it might be main transformer the front blinking led means the set in is safety mode and wont boot up because of a fault
Aug 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No picture / No Sound / No nothing
that sounds like the Hi voltage transformer went bad.. If your a tech simply disconnect the horizontal output transistor and see if thats shorted. If it is then it is for sure the HV transformer. If its not shorted look in the main power supply. Its cost is around 40 bucks or so and the transistor is about 15 to 20 bucks. This entire repair should cost ya around 150 to 175. So if you decide this tv is the one you like then have it fixed. Good Luck
Jun 01, 2006 | Sony KV-36FS100 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
