Question about Dell 2130cn / 3110cn / 3115cn / 3130cn / 5110cn Color Laser Printers
I am working on a Dell Color Laser 2130cn and it print light on the left side of Form only from left edge of form in around 3" which is realy the right side of the Printer causing Light Print because it is a face down exit delivery Printer. I replaced the PHD and it did improve but still light print. Befor I replaced the PHD I did a half print test which allowed myself to view the Image Drum's and could see on all 4 Image Drums that the Toner was light on all 4 Image Drums. But after replacing the PHD now cannot tell if the Toner is Light on the Image Drums anymore because it has darkened a bit with replacing the PHD but still may be a little light? I was thinking trying a Image Transfer Belt next then the High Voltage Power Supply after that. I do not believe it could be a Laser Unit problem because it is all 4 colors? I cannot seem to find anything on this problem Googling anywhere. Any ideas or should I go my proposed way of trying to resolve this problem?
    Sergeant:
  • Dell Expert
  • 296 Answers
Try cleaning the laser lenses.
Posted on Dec 22, 2014
What does the User Intervention on a Dell 2130CN printer mean?
Either the print was stopped from printing. check print queue.
Or the printer was turned off during print
Open the inspection doors
pull out ink cartridge, put back in
Check for paper stuck in printer
make sure you print Queue is empty
remove usb and turn off pc
restart and plug usb back
Mar 11, 2015 | Dell 2130cn Laser Printer
Dell 2130 cn printer only printing in black and white
check color toner cartridge levels. What operating ststem are you using and what printer driver are you using?
if it is an IMac have a look at the post below
http://forums.macrumors.com/showthread.php?t=1069139
Aug 24, 2014 | Dell 2130cn Laser Printer
Dell 3110CN printer issue
This could be fold back where the page being printed is wider then the printers set up page. Make sure print to fit page is selected.
hope this helps!!!
May 15, 2013 | Dell 2130cn / 3110cn / 3115cn / 3130cn /...
Ink on left hand side of page very faint
First make sure that the print cartridge has enough toner. If the toner is OK, it is most likely be due to dust/ toner dust accumulation at the laser reflecting mirrors inside the printer, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
Apr 07, 2011 | Dell 2130cn Laser Printer
I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Mar 28, 2011 | IBM Office Equipment & Supplies
Where can i buy a print head device for a Dell 2130CN
At Dell.com - They call it a Drum Imaging Kit
Manufacturer Part# : Y459D ' Dell Part# : 330-1435
Dec 15, 2010 | Dell 2130cn Laser Printer
How do you set the printer to print in black only after a color toner is gone. the printer is a dell 2130cn clolr laser
Try going in to your printer properties
Start - Printers and Faxes - RMB on default printer - properties (From drop down menu) - Advanced - Printing Defaults - Check the "Greyscale" box.
Now this the route using XP and a Canon printer, yours will be similar but also may differ slightly.
May 11, 2010 | Dell 2130cn Laser Printer
Dell 2130cn prints black as gray after only a few hundred pages says black toner is about 80%
Hello sir; I believe that is toner cartridge problem, bring back the old one to the store where you perchased befor for exchange.
Jan 18, 2010 | Dell 2130cn Laser Printer
Dell 2130cn / 3110cn / 3115cn / 3130cn / 5110cn Color Laser Printers Logo
140 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
