Question about Samsung Audio Players & Recorders
Samsung home cinema HT-TZ212 comes up protected how do I fix this
UNPLUGING REMOVE SPEAKERS
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 5 Answers
SOURCE: when i turn samsung HT-TZ212 home cinema system on
Hi , your amp board need to replace , get one from ebay.
Posted on Apr 04, 2010
My samsung ht-x30 shuts down after 5 secs and displays protection
Hello
disconnect all the speaker connections, and switch ON the set only, and see whether any protection function energizes or not. If yes, the fault is with the amp itself, and most likely to some damge of components in the output circuit section of the amp. If the amp does not show any protection, when all the speakers are disconnected, make sure that, any one amoung the speakers be the cause of this problem. Connect one after an other and find out which one causes protection circuit to energize. OK.
Dec 28, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
My samsung home cinema ht-tz212 wont play discs, just says loading, then open or disc error??? ive tried cleaning fluid lense cleaner with no luck ???
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Jan 31, 2010 | Samsung Audio Players & Recorders
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection displayed and shuts off When I press the power button Protection is appear on screen on my home cinema system dvd player
check wiring on speakers it sounds like you have some wires touching together somewhere or you have a bad speaker.
Jun 15, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Samsung ht-tz212 protect!
resistor smr60 is 470r / 470 ohm
Nov 08, 2008 | Audio Players & Recorders
61 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
