Question about Philips JVC HD-52G587 HD52G587 Lamp with Housing TS-CL110UAA
Sound cuts in and out and sounds like a short in speaker
    Habit-Forming:
  • 146 Answers
Sounds like a short to me also or just a bad connection.
Posted on Dec 13, 2014
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
Nov 04, 2013 | Cars & Trucks
I have a Denon AVR-587. It has worked fine for 2-3 years, but ever since I tried to connect it to a different set of speakers, it cuts out after a few minutes and I hear this loud clicking sound coming...
There is a short either on the speaker wires to the speakers or the speakers are defective (some sort of a short or too low of resistance). Lastly, check to see if a stray strand of wire is not touch the left and right terminals. Any short in the network (wire, lack of insulation, staple, screw, etc. ) will cause the system to clip.
Nov 10, 2010 | Denon AVR-587
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
Bose 312 Sound Cuts in and out
Most amplifiers design to cut out when there is an overload, such as playing the music too loud. It helps protect the device from being damaged. If the device does it at low volume, and does it sometimes, check the wring to the speaker, something might be shorting it out intermitently.
Nov 28, 2009 | Bose (321GS) System
The sound cuts out all the time for a second
you might have a short in your wiring somewhere. If your power wire touches any kind of metal it will ground it out causing it to cut off.
Oct 31, 2009 | Car Audio & Video
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Kenwood vr 615 speaker sound cuts out
it means there is some shorting in the speakers.. check for the shorting
Dec 14, 2008 | Audio Players & Recorders
My speakers work for a short while then cut out - please help
have you ever tried to instal a sound blaster sound card on your machine
Dec 12, 2008 | Logitech Z-5500 Computer Speakers
Durabrand DB1215 car radio
I have a db 1210 and i need the wireing plug for the speakers can you help
Jun 04, 2008 | Durabrand DB1200 CD Player
No sound
Sounds like poor wiring connections. Also, if one speaker shorts out, ALL speakers will shut off, so make sure there aren't any loose wires behind the radio or at the speakers. Sometimes wires get pinched in the door jamb and create a short as well.
Sep 25, 2007 | Alpine CDE-9843 CD Player
Philips JVC HD-52G587 HD52G587 Lamp with Housing TS-CL110UAA Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
