Question about Refrigerators
How do you stop the condensation in breathing tube
    Novelist:
  • 187 Answers
I am assuming the breathing tube is the evaporator drain underneath the refrigerator freezer. You do not stop the condensation. This tube gets rid of the condensate that forms during defrost of the evaporator. The condensate drains into a provided collecton pan under your refrigerator. If the tubing has fallen out, this can cause the condensate to pour out into the floor and can cause damage to flooring and walls.
Pull the refrigerator out and remove the 6 to 8 1/4 inch drive screws that hold on the cardboard cover on the lower back side. Find the tubing and direct it back into the evaporation pan provided. It will be near or under the condensor fan.
Hope this helps.
Posted on Dec 14, 2014
Testimonial: "The question was.How to stop the conde nsation in my breathing tube on my bi-pap machine or rainout as its called."
  • Sorry, your question was posted in refrigerator section. My son has one your machines and I have never used one and have never used one. The doctor who fitted you up with it may have some feed back to solve your problem.
  • I was thinking about this problem and I am sure it has to do with the relative humidity of the air coming up to the face mask. If the relative humidity is to high and the hose is subjected to cool air surrounding it, the moisture inside can condense if the dew point is reached. So the cure would either be reduce the relative humidity of the air by not producing as much moisture or warming the hose so it will not reach the dew point and stay above the dew point. To keep the hose warm, try raising the temperature of the room or possibly wrapping a small electric blanket around the hose. Hope this helps
Hotpoint WDUD9640 washer dryer clothes coming out wet and hot
check the exhaust tube externally and internally for excess lint build-up on the sides. You may not have the vent obstructed, but you may have the venting restricted. Clean out lint if there is excess. It may need a good scraping/ brushing to help your machine breathe. Just an extra thought.
Mar 11, 2018 | Hotpoint Dryers
Where exactly is the orifice tube located on a 1993 GMC C1500 4.3L pick up truck.
In the bottom tube of the condenser core. Remove the grill and the tube that comes up at about 60 degrees on the condenser.
If you look closely at the tube you will see a small dimple about 4ins along from the connector. That dimple is what stops the orifice tube from traveling further down the condenser tube.
Jun 10, 2015 | GMC C1500 Cars & Trucks
There is water inside only the right side crisper from excessive condensation ,no change after adjusting vent on drawer to either low or high. Any suggestions?
Make sure the fridge is not overfilled or the back of it isn't covered (leave at least 2-3" from the wall). It sounds like it's heating up (don't put hot food in the fridge), so you need to remove items that don't need to be there. Make sure that the airway is clear to the crisper as it needs to "breathe" to stop condensation forming.
Mar 02, 2012 | Kenmore Refrigerators
Hello. My freezer part of my subzero 690 is getting too cold. The temperature has dropped to -8. My normal setting is zero. I tried raising the setting to +5 with no effect. I tried turning the whole...
check u tube for problem solving videos.
There are a number of great troubleshooting u tube videos, which show you what to look for and many of the fixes are really simple and are universal for all fridges. The simplest is that you left a door open, moisture got in and froze causing ice to build up, so you have to thaw it totally, not just turn it off. I moved my older subzero and think one of the tubes must have been knocked and it lost its Freon, so stopped cooling. The cost of having it recharged was so prohibitive (ie environmental disposal issue meant it had to be moved to a special location fixed and moved back at my expense or Subzero said it was a closed unit and you had to replace the whole thing$ 1,300 for the condenser alone) so, I tossed it + bought another used one until my renovation was done.
Generally with any fridge, there seems to be 2 possible Simple reasons:
1. DEFROST MODE PROBLEM it is stuck in defrost mode
. a)the defrosting tube is plugged
b)The tube or thermostat is frozen, most likely because someone left the door open or the seal is poor;
c) termostat defective-untube video explained how to test circuit;
4. CONDENSER ISSUES: the condenser coolant gas is low and can be easily recharged- see the u tube how to video;
5. Condenser is dirty and cannot breathe- vacuum it;
6. The condenser overheated and needs replacing . 4-6 will have the condenser blowing cool not warm air.
I have had this problem with the fridge portion of my SUBZERO bottom freezer and Subzero (and a repair person ) gave me some good advice, which should also apply to yours, but you might want to call them yourself:
1. Simplest fix- if the defrost tube is blocked or frozen, the defrost cycle will stick on preventing cooling (either freezing up or heating for the defrost cycle not cooling); Some subzero models are especially prone to this. I could see part of my tube inside the fridge on the back wall close to the bottom where it drains and removed the panels to expose and clean it;
2. You should pull it out and unplug it to get it to defrost fully. After doing that once, I made sure my fridge was on a separate circuit or switched!! Yours might not be the same, but on mine the tubes run through the fridge to get to the freezer so both parts have to defrost;
3. Subzero fridge and freezer each have their own independent condensers, so you might be hearing the condenser for the fridge running, even though one part is turned off.
4. Check the thermostat to see if it is working. There is a good u tube video on this.
5 Some of the u tube videos show how to "recharge" the Freon. Subzero told me these are sealed units and could not be done, so regardless of the problem, the condenser had to be replaced. The subzero repair person was really helpful + checked the Freon or gas level (Mine was old enough that it was Freon not the newer environmental stuff) so they would have to haul it away to drain and recharge it + then the condenser might still have to be replaced.
Good luck
Joan
Jan 15, 2011 | Sub-Zero 690 Side by Side Refrigerator
Hi, I have a patient complaining that the tubing pops out when doing breathing treatment. What is the cause of that and how can we fix it? Thank you, Elizabeth
It sounds like she is breathing out too hard and the tube may be slightly stretchec and come off easily- try a new tube and tell her not breathe slower when she is exhaling
Oct 21, 2010 | Probasics Rite-Neb Mini Compressor...
What does front breathing mean?
"Front Breathing" usually means the refrigerator has a fan forced cooling system (condenser fan) that gets it cool air (and usually exhausts the warm air) via a front vent. The vent is usually located on the bottom or top.
Aug 10, 2009 | Silver King 1242.90 Front Breathing...
How exactly do snorkels work when you are under the water???
Or more to the point: Snorkels don't work under water. They work on the surface by allowing the wearer to have his/her face in the water so that one can look at what is going on and the top of the snorkel is several inches above the surface allowing the user to breath through the tube. If, as often happens, the snorkel gets water in it, there is a trap at the bottom that catches it so you don't **** it into your lungs and on the next exhale you do so forcefully and this expels all the water from the tube and allows you to continue breathing.
Dec 01, 2008 | Aeris Snorkeling Bag
Trane HVAC Unit
If your condenser blow air up through the top of the condenser and you are concern about rain water affecting the unit.
You can install a roof or rain hood about 4ft above the unit to keep the rain off, The unit must be able to blow air off without causing Hi head pressure to affect the unit, The condenser must breathe or desipate heat freely.
Tell me if your question answered or if it works for you.
Mar 31, 2008 | Heating & Cooling
Goodman 90% gas heater condensation build up
If the exhaust comes off the top of the furnace, you will need to make sure the condensation will drain all the way back to the condensate outlet found at the base of the inducer blower. If you are having to remove the tube from the pressure switch, there must be a blockage from the inducer down to where ever it drains to. Check to see if all tubes are free of blockages and if there is a condensate trap, clean it out. If the pressure tube you mentioned is facing up toward the blower allowing water to flow into it, reposition it so water will not enter the tube.
Oct 17, 2007 | Ruud UAKA030 Air Conditioner
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
