Question about Haier Washing Machines
Hi i put my wasing machine at a 60 wash and wanted to spin it instead it wont let me change it any ideas to how i do it
Tried moving it to spin wont let me then tried opening an dclosing door and restarting but just keeps going back to where i set it by mistake the 1 st time
Try unplugging it for a few minutes
Posted on Dec 12, 2014
Wasing machine washes fine, once it gets to the spin cycle it stops and just makes a slight hmmmmmm sound. and wont drain or spin.
Wendy,
What brand of washer do you have? If you put that info in, it did not come through with your question and we need that info to give you the correct information to help you fix your problem.
Jun 23, 2015 | Washing Machines
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Mar 11, 2014 | Beko WM5140W
Washer will not spin out....acts like no power...wases fine ?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 28, 2010 | Roper Washing Machines
After wasing dark cloth, there a lint on them, how
i think the paint inside the washing machine started to peel,and maybe that's the cause of white lint.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | Washing Machines
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Amanna wasing machine 3.2 cu. ft. top loader
i would try removing the lower acess panel(2 5/16 screws . from there you should be able to see where the "ticjing" noise is coming from, likely source is cracks in belt assy
Oct 07, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Beko 520w wasing machine
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
