Question about Keurig K350 2.0 Brewer
My keurig 2.0 will not brew. Everything works fine up until you press the brew button. It sounds like it is going to brew for about a half a second and then it just stops. A fee drops of wwater come o
It seems like we have tried everything! Took all of the parts off and cleaned them, used a dish towel to wipe out any crevices in the keurig, tried taking the water filter out, etc. Please help!!
Any answer to this? Mine is doing the exact same thing and it's only a week old.
Posted on Jan 02, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
If it is an older one it has probably limed up and needs cleaned with white vinegar. Run through it repeatedly until things come out clean & not cloudy.
Posted on Dec 14, 2014
All my lights are flashing and they don't want to stop mashene is not working
1. Press the auto off and small cup at the same time. Then Immediately release and re-press the small cup three times.
When it works the only light showing will be the descale light.
2. Press the small cup button then auto off button then release small cup and then auto off, when this works the lights on will be the power button light and the descale light.
ALL OF THE ABOVE DURING THE PROCEDURE MUST BEEN DONE FAST OR RAPIDLY.
3. When both of the above lights are on,(power and descale), unplug for about 3 to 5 seconds... and plug back in. The brewer should come to life and work normally.
Below is the address and Phone number to Keurig warranty service.
Keurig, Incorporated
101 Edgewater Drive
Wakefield, MA 01880
1-866-901-BREW (2739)
Nov 12, 2014 | Keurig B40 Single Cup Home Brewing System...
Keurig won't brew coffee
Take it back for an exchange. Not sure what model you have, but Keurig has a class action law suit going on because of the many problems they are having with their coffee makers. Again, take it back for an exchange (what I did).
Dec 31, 2013 | Keurig Coffee Makers & Espresso Machines
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
I have a keurig b30 and has been working great but now it will not recognize any of my cups so the flashing blue light will not come on to start brewing? none of them are clear and have all worked in the...
I haven't solved the problem, but I continue to disassemble my K30. Most likely points of failure for the blue start light not coming on appear to be a sensor to detect the cup is in place (two small holes on the left/right front edge of the cup holder) or a sensor in the resovoir lid where the blue pin presses on a pressure switch. I did find that the red wire to this switch gets caught in the lid hinge and may be damaged. I will post more if I finally discover the root cause but may just go to Bed Bath & Beyond and buy the resovoir model with a 2 year warranty. Lesson learned. Cheap switches and mechanical devices.
Nov 06, 2010 | Keurig B30 Mini Coffee Maker
Keurig b40 elite,when plugged in, all lights keep blinking.
After trying everything that I have read about I finely made up my mind that this thing could not be fixed so I decided to just push all the buttons and hold them down for awhile when I let them go the lights went off and now it is working just fine.
May 25, 2010 | Keurig Elite B40 Coffee Maker
I PUT SWITCH ON FULL BREW AND IT STOPS WITHIN 30 SECONDS. WHEN I PUT IT ON HALF BREW IT DOESN'T STOP RUNNING
It sounds to me like the Timer board is damaged, to test it set the small lock lever on the board to on (hopefully you have the electronic timer board in there) then select the cycle half or full then hold down the brew button until you hear 3 clicks then release. After about 1min or if using a measuring pitcher stop the brewer a 2ltrs, by turning the on/off switch off. Wait until flow stops then check water level and note. Turn brewer back on and press and release brew button and this time if it stops and gives you the same amount as you just got when programming then the timer is fine, just recalibrate it for full brew using the method above.
May 18, 2009 | Bunn U3 / SS 20500-0000 Coffee Maker
Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Feb 12, 2009 | Keurig B50 Coffee Maker
Cucina Pro Double Coffee Brew Station 1711 Series We have had this unit for about 2 months. It has been operating fine until about a week ago when the left side ON/OFF light and the TIMER light have both...
It is an indicator that means you have to clean that side - you then press two of the buttons for 5_10 seconds to stop the blinking . but i can't find my manual and can't figure out which two buttons!
Jun 28, 2008 | Heating & Cooling
WIll not brew
Keurig has a customer service center that you can call. The technicians there will help you with almost any problem you have. That number is 1-866-901-2739. Most problems are caused by blockage in the needles. You have to clean both the one in the k-cup holder and the top lid area. A tooth pick works great for that. Good luck.
Nov 13, 2007 | Keurig Elite B40 Coffee Maker
Keurig K350 2.0 Brewer Logo
108 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
