Question about Viper Vehicle Parts & Accessories
How do I program my viper replacement transmitter for my car.
I can seem to program these new remoter I just bought. so I know I am doing something wrong please help
    Sergeant:
  • 213 Answers
Dear Marta,
Here is a hands on to watch and program as you go. Follow to the link. How To program DEI Viper Python Avital Sidewinder Valet Hornet Alarm...
Here is another look. 1f Responder LE Remote Pairing
For your direct contact to Viper follow this link for any question. Viper Support
Fare. Well.
Posted on Dec 12, 2014
How to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
Aug 20, 2012 | 7752V Replacement Transmitter Supercode...
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
Cannot program a replacement transmitter.
unplug your antenna and short out all the terminals on the antenna together then try again
Jun 05, 2010 | Remote Start System
Programming Of Viper 479V After Water Damage
if you know where your valet switch is try to turn the ignition on and press the switch 1 time within 10sec and that should disable your security system for now. then to program the remote you turn the ignition on and press the switch once and hold a second time, within a few seconds the siren will beep once then press the lock button on the transmitter and the siren should beep again then let go of the switch and turn key off. If no beep is heard when you push lock then the transmitter is no good
May 23, 2010 | Directed Electronics 479V Remote Gen 2...
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Oct 09, 2009 | 5900 SST 2-Way Security System / Remote...
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
Keyless remote
THIS IS THE PROCEDURE, FOLLOW IT EXACTLY OR IT WILL NOT WORK.
Transmitter Programming
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation
Sep 25, 2008 | 2006 Pontiac G6
Vehicle Parts & Accessories Logo
754 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
