Question about ASUS Tablets & eReaders
My new...never used...just fully charged Asus TF700T tablet won't turn on. the green light went out when i tried to turn it on and i just get a vibration after a few seconds. i have tried holding vol
See above question....please help..................................................................................................................................................
  • 21 Answers
Sounds faulty im sorry to say. When you press and hold the on off button, you are releasing it as soon as you feel the vibration arent you. Holding the on off button too long will begin the start procedure but end it before it completes.
Posted on Feb 06, 2015
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
SOURCE: My kindle is frozen I followed the troubleshooting
screen is half blank when i bring up book i'm reading
Posted on Jun 09, 2011
TechyDrood
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Posted on Oct 16, 2011
SOURCE: my archos 28 internet tablet wont turn on... the light comes on and then it goes off after like 7 seconds
LOL, you're up the creek. Never buy a computer that does not have a CD Drive on it because that is what you need now.
May the AC Adapter Power Cord is bad. Some of them have a indicator light on them when you plug them in the wall. Does yours have a light on it and does it light up?
When you plug the power cord in the tablet do you see any lights?
Posted on Apr 25, 2012
gamestoysman
SOURCE: My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Posted on Dec 12, 2012
Start using a new kindle
Leave the kindle charging over night. The yellow light will turn green when fully charged. Or watch the lights and time when the green light comes on.Make sure you have the kindle wifi off when not in use as the battery uses memory when it is on.
Nov 02, 2014 | Amazon Kindle Paperwhite
Need user guide for infinity android 10.1 8gb
For the ASUS Transformer Pad Infinity TF700T? If so, the link to download the manual is below:
http://dlcdnet.asus.com/pub/ASUS/EeePAD/TF700T/e7048_Ttransformer_TF700_emanual.pdf
Sep 02, 2014 | Tablets & eReaders
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Won't connect to Wi Fi
i have a asus transformer t100ta and a brighthouse motorola modem my problem was the router in the motorola its security would not let it connect so i got a new router and had bright house turn off their wireless now all connections are fine hope this helps
Jul 09, 2014 | ASUS Tablets & eReaders
After tablet drop on the floor from the couch I could not turn it on , after plug in green light come
if you are new to this, then the green light should be charging and that was because your tablet ran out of batteries somehow (it happens) I hope I helped! :D
Feb 14, 2014 | ASUS Tablets & eReaders
Dec 11, 2012 | ASUS Transformer Tf300t Tablet
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
My kindle wi-fi is not working. I went to turn it on and the light came on but stayed at the screen saver screen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Nov 13, 2010 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
63 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
