Question about Home
How? I have Steinel NightMatic 3000, but after coming on at dusk and setting the twilight level, it remains on all the time. Is there a reset I can make? I've tried all settings to try and get the unit working. can you advise?
  • 75 Answers
SOURCE: Camera looses date & time setting
There is a cmos battery (or a memory battery) on the main circuit that like any battery wears out eventually. If you are familiar with repairing electronic circuits you can get the part from Olympus. There is no part number just "memory battery for C-740" will suffice. Your other two choices are to take the camera to a shop where they can do the kob for you. Don't let them sell you a complete new board, you don't need one. Not for this problem anyway. Or you can ignore the problem and reset the camera (or not)each time you change batteries.
Posted on Mar 31, 2007
SOURCE: Bravo II disk pickup problem
Chances are your burner is probably going/gone bad. Simply open the system carefully and replace the drive. Worked for me! hope this helps.
Posted on May 12, 2008
  • 28 Answers
SOURCE: astar LTV32PRM
please call 323-7667-6030 I will try to go through with you how to clear the code.
Posted on Dec 09, 2008
  • 87 Answers
SOURCE: X5 Suspension won't self-adjust. Remains in the lowered position
Good day!
I would suggest you to check the air suspension Fuse located at right side of trunk. If it is faulty just try to put new fuse and observe it if you can not find fault then bring your car to the BMW service center to have proper investigation.
Thanks,
Ck
Posted on Feb 23, 2010
aquaman987
  • 927 Answers
SOURCE: Utilitech Outdoor Digital Photocell
SearchElf - Find Utilitech Timer Instructions
Here is a link to the instructions.
Posted on Nov 30, 2010
How do you set it to come on at dusk and go off 8 hours later?
Since dusk time changes there is no way to do that . Pick a time .
Dec 03, 2015 | Hardware & Accessories
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
Dec 02, 2012 | GE Home
Ace digital timer & cord combo pack
Buy another outdoor dawn-dusk timer.
Timers can be damaged by simple power outage, when power resumes there is a surge.
Dec 20, 2011 | Ace Hardware Ace Digital Timer and Cord...
I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
Call Intermatic.
You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
Instruction manual has troubleshoot checklist.
Timer comes with 1 year limited warranty.
Open following links for ez instructions, wiring diagrams, and battery illustration:
http://waterheatertimer.org/ST01C-program.html
Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Why does it tre?10 minuets for headlites to turn off on 2002 Buick LeSabe
Some cars have a delay to give person light to go up their walkway to the house.Check owners manual it might tell you how to reset it.
Dec 07, 2010 | 2002 Buick LeSabre
I need to know how to reset the timer. Right now it says DUSK, what does that mean?
You posted under ST01C Intermatic timer.
DUSK is the dusk-to-dawn option available with astronomic timers like the ST01C.
If the ST01C is not your timer, add a comment with your timer brand.
I have tested the ST01C and many other timers.
To diagnose the timer, press manual override (on-off button) to see if timer operates Load.
The ST01C will not operate the Load if battery is bad, or if timer has gone bad.
Replace CR2 battery, and then re-program current time and day.
Current day settings are lost when battery goes bad, but the on-off programming remains indefinitely inside timer memory until the reset button is pushed.
To clear timer memory, hold down on-off button and push tiny round reset button for several seconds.
The following link shows the manual and EZ steps to reset timer:
The link also shows other timers in case you have a different brand.
Nov 11, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Home Logo
74 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
