Question about Keurig 2.0 Coffee Carafe
DESCALING SOLUTION How do I get water filters and descaling solution?
    Scholar:
  • 159 Answers
Lowes home improvement store or home depot stores or Ace Hardware stores might carry what.
Posted on Dec 12, 2014
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
I now use soft, filtered water each day. The "descale" message still comes up every 60 days. Is descaling that frequently, normal?
yes you will still need to descale it
soft filtered water still contains minerals and calcium but in lesser quantities
if you wish to avoid descaling use distilled water or demineralized water
Sep 18, 2016 | Breville Coffee Makers & Espresso Machines
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
Hi there, I have owned my Keurig for just under a year and it has recently started only making half cups. I descaled it and I am not sure what else there is that I am doing wrong to not get a whole cup?...
Hi, Jessica...
Do you live in an area that has hard water? Do you use filtered water?
These might have some bearing on your problem.
There is "descaling", and then there is "descaling". Some people use a weak vinegar solution only once. Other people use several full pots in succession of straight white vinegar (full strength), followed by several full pots of water to flush the vinegar out. And some people use packaged "descaling" compounds that may or may not be effective.
Even after a heavy-duty descaling, there may (in the case of mineral deposits) be bits of "gunk" that were loosened by the descaling, and that settled into the drain holes over the filter basket. Think of a clogged shower head. Such clogs (which can be observed if you run the coffee maker without the basket) can sometimes be cleared with a needle or a toothpick.
Worst-case scenario? It may be that your Keurig is still under warranty.
Mar 02, 2011 | Keurig Coffee Makers & Espresso Machines
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
I want descalcificacian saeco easy sup 021ye what butons y press?
Warning! Never use vinegar as a descaling agent. You can use any commercially available non-toxic, non-harmful descaling product for coffee machines.
Descaling is necessary every 2 months; should water be very hard, descale the machine more frequently. The machine must be on; it automatically controls the distribution of the descaling solution.
  1. Switch off the machine.
  2. Fill the water tank with the descaling solution.
  3. Place a large receptacle beneath the steam tube.
  4. Switch on the machine.
  5. Open the knob.
    The descaling process starts.
  6. Dispense the descaling solution into the receptacle.
  7. After about 30 seconds close the knob.
  8. Switch off the machine and remove the receptacle.
  9. After 10 minutes, follow instructions 1 to 8 to the water tank is empty.
  10. Rinse out the tank and fill it with fresh drinking water.
  11. Place a large receptacle beneath the steam tube.
  12. Switch on the machine.
  13. Open the knob to rinse.
  14. If the receptacle fi lls, empty it.
  15. When no water is left, turn the knob to close the valve.
    Remove the container.
After descaling the machine, reload the machine circuit. Install the cartridge filter again in the water tank.
Jul 23, 2008 | Saeco Easy Espresso Machine
Keurig 2.0 Coffee Carafe Logo
464 people viewed this question
Top Keurig Home Experts
john h
Tom Chichester
Are you a Keurig Home Expert? Answer questions, earn points and help others
