Question about Epson WorkForce WF-3520 All-in-One Inkjet Printer
What is the error code0x10 on my Epson WF3520
I tried shutting down the printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Go to http://www.epson.com/cgi-bin/Store/jsp/index.do?ref=epson_wmr_s_us
Posted on Dec 14, 2014
I cannot find the online user manual for the WF-3620!
You can find easily by google it, Just type the model number of printer with user manual or user guide
you can use this key work " epson wf-3530 user's guide "
https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?UseCookie=yes&oid=232591&infoType=Doc
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
Feb 01, 2016 | Epson WorkForce WF-3620 Wireless Color...
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
HOW DO I FIX ERROR 0X05
that an internet explorer problem try this (http://www.solvusoft.com/en/errors/runtime-errors/microsoft-corporation/internet-explorer/0x05-internet-explorer-8-error-code-0x05/
Oct 23, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
0x95 error
Epson Printer Error 0x95 occurs when the printer head is saturated,i.e; cleaned. Error may be due to installation or uninstallation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Check Epson Printer Ink head. Generally, Printer ink is dirty meanwhile it is inked up properly because the ink pad is full. Often due to unbalance ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Try to switch on your Epson printer.
  • Then "press+hold" together to stop ink power buttons.
  • Wait for sometimes while the printer switches self OFF.
  • Next switch back ON and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about whether your error existence effectively solved.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Apr 01, 2014 | Epson B510DN InkJet Printer
Was printing labels and the feeder pulled the page through crooked so it jammed. I pulled the paper out, it ripped, I opened the printer and got the remaining peices out and shut off the printer. When I...
ALthough you didnt give the model of the printer this has helped reset it on other epson printers.
unplug the printer from both USB and Power.
Hold down power button and then plug in the printer while the power is held down.
if this doesn't do it try holding down the paper button and the power, while plugging in. since this can be tricky, plug it into a power strip so you can power off and on easily. This is a help at the bottom for a R220 that mentions somthing similar.
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/parts_1.htm
Mar 11, 2011 | Epson Office Equipment & Supplies
Epson cx7800 error e-04
make sure the ink cover was down tight. Shut down the printer open it up and resecure the ink cover. That has fixed this error in many a case.
Jul 31, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Error e5
E-5 error on dfx --carriage load measurement, you will need a servicer.
Feb 18, 2008 | Epson DFX-8500 Matrix Printer
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson WorkForce WF-3520 All-in-One Inkjet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
