Question about Electrolux Refrigerators
I am trying to purchase an Electrolux freezer EUN1272, cant find anywhere, anyone help
On line searches
Electrolux freezer basket
it has to be in the holders on the side rail for the basket so it does not twist and fall down make sure it is clipped in
Mar 31, 2014 | Electrolux EW23BC71IS Energy Star Counter...
I am after a manual for the electrolux dishlex dx303. thanks for the help.
Hi I am Kelly.
This is not the exact manual but maybe it will help. (DX301)
http://www.dishlex.com.au/common/pdf/156987653_DX301.pdf
I searched for sometime and did not find a single DX303 manual on-line.
If this was not helpful just don't rate the post and maybe another expert just by chance happens to have a copy of the manual and can direct you to a link for the manual.
I just recall looking for this exact manual several times for other askers without success. I know for a fact I have lost over 3 hours searching for the manual your seeking. It just does not seem to be anywhere other than with the retailers in the stores... (you might ask for a copy)
Kelly
Sep 14, 2011 | Electrolux Dishwashers
I need a new base plate for an Electrolux vacuum power nozzle model #1693 Are these available anywhere?
This part is not available through any vacuum parts house / vacuum store. You would have to check your yellow pages to see if there is a local Electrolux dealer in your area. You might also try to find Electrolux on line and contact them that way.
Apr 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
Jun 15, 2009 | Troy Garden
We have a GE PFSS6PKWSS with french doors and bottom freezer. The ice-maker has never made the quantity (100 to 130) of ice cubes stated in the owners manual. We consider ourselves lucky if we get 50 cubes...
try turning up the freezer making it colder the ice maker needs a specific temperature to make ice also make sure you water walve is turn ed on fully and there are no kinks anywhere in the water line
but to be honest rarely anyone gets 130 cubes thats under perfect standards they used in factory perfect temp for a whole day nobody changing the temp(like we do by opening the door) and with perfect water preassure and such
good  luck  ask any questions you might have
Jun 08, 2009 | GE Refrigerators
Refrigerators Logo
54 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
