Can a Utilitech UTTNOREM2 remote control outlet be programmed to a different remote?
My problem is that I can't find one of the remotes and I would like to see if the remote can be programmed for the different outlet as it does nothing. I changed the battery in the remote and the light comes on but the outlet doesn't light that it has received a signal.
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
  • 16 Answers
SOURCE: my bose pmcii lcd remote control does not receive a signal from a bose lifestyle 48 receiver
Have you tried using the remote antenna supplied with the Bose system? This connects to the "Remote antenna" socket on the rear of the media centre and is made up of 2 parts: a shielded section (black in colour) that runs past any sources of interference - mains or signal cables, other electronics products - and the unshielded antenna (clear plastic covered copper wire) that must be fully extended vertically to act as an aerial. Position this away from sources of interference and as close to the second room as possible (Bose do a longer version, free of charge in some countries....)
The remotes only have a range of up to 20metres - this will drop the more walls it passes through and the thicker the walls. Any interference can affect this - radio transmitting equipment (WiFi, video sender, but especially products transmitting on the same frequency - 27MHz or 40MHz, e.g wirless thermostats or alarm systems....) or products with poorly shielded transformers. Experiment with swtiching off other electical equipment (including lights if they have a transformer - e.g. halogen spot lamps). If you identify a source, can you move it away.....?
Posted on Jan 16, 2008
SOURCE: tv remote src350a motorola
Turn on tv press and hold the select button and mute. Hold until LED button lights up. Press up arrow, release, press and release. The light will blink each time you hold the button. When tv turns off press select to store the code. Changeing the stream press and hold mute and select release when light comes on. Press and release the A key. Enter 0 ro run stream one enter 1 for stream 2 and 2 for stream 3
Posted on Jul 09, 2008
  • 5 Answers
SOURCE: RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Posted on Oct 12, 2008
SOURCE: programming my remote
http://66.77.167.109/rcaaccessories/BrandCode.do
go here for your codes to any rca remote
Posted on Mar 22, 2009
How to program a remote to a tv
Programming procedure to remote control differ brand to brands. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 20, 2013 | LG AKB73615316 Remote Control
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
Sep 22, 2013 | Hardware & Accessories
The remote to the tv does not work on my lg42 inch but on the other tv it works.
SOunds like the remote needs to be reprogrammed with codes to work for both. They would operate on two different codes. Need to look at the remote device to see what codes are recommended in the setup.Universal remotes have their own codes that don't always work on other remotes too. Also take into consideration, does the remote go to the tv you are trying to control or are you using a different remote, trying to control your different units from the same remote. Comcast, Tivo, Directv, etc all come with their own remotes that can be programmed to operate more than one device, similar to that of a universal remote.
Google "program your remote for a tv" to get different results. You may need to google the model # of your remote too to see how to program it properly.
Good luck.
Mar 10, 2011 | LG 42LG30 42 in. LCD HDTV
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
How to program utilitech 1 outlet daily timer
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Dec 01, 2010 | Day-Timer Hardware & Accessories
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Dec 01, 2009 | Day-Timer Hardware & Accessories
How do i program my remote to onother tv
Your instruction manual will list all of the codes to program your remote for different tv's. Failing that you can check your manufacturers website for the same information.
Jul 10, 2009 | Universal Remote Control MX-3000 LCD...
Programming universal remotes
There really isnt a "general" way to program a remote most of them require slightly different sequences. what kind of remote do you have?
hope that helps.
Jan 27, 2008 | Excalibur 201CS Remote Control
Televison & Video Logo
495 people viewed this question
Top Televison & Video Experts
