Question about Legacy - American II: 2 Channel 2000W American II Series LA-1990 Car Audio Amplifier
Optimum sound performance needed
I have an american legacy 2400 bridgeable amp and two kenwood 1200 watt subs and and when i raise the volume of my head unit the bass don't sound as great as i would expect.
there is an adjustment lever on the amp with hpf and lpf (i think) and the main gain whats the ideal setting that my amp should be on and whats the ideal setting for the bass settings on my head unit as well.
  • 111 Answers
1) legacy products are highly overrated and i have never seen one put out the power it claims
2) if you are running the amp bridged, you need to match the impedance of the speakers to the amps highest output impedance, otherwise your system will not sound all that great...
what size fuse or fuses does your amp use? what size wire did you install with (power and ground)? did you connect direct to battery or did you connect to a fuse block or similar? did you use a stiffening capacitor? does it sound like it is clipping when you turn it up or is it just distorted? what kind of box are you using for the speakers (ported, vented, sealed, bandpass)?
if you give me the model number of your speakers and your amplifier i can probably help you more, but with the information you have provided, this is all i can offer..
hope it helps,
Posted on Nov 16, 2007
I have two 12 inch 1200 watt kenwood excelons and i want to bridge them to the amp but i can barely turn it up with out blowing fuses
Please check the impedance of those subs. Are they 4 or 8 ohm speakers? Do they have dual voice coils? this app may not be capable of handling dual voice coil four ohms and you're trying to bring it down to a 2 ohm mono.
Dec 19, 2013 | Kenwood KAC-7201 Car Audio Amplifier
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
May 07, 2011 | Sony Xplod 800W Class AB Bridgeable...
I bought a new 1200 watt xplod amp and pluged it to a 1200 watt double coil sub with my alpine headunit the head unit is too old so i got a new xplod head unit but now i got a really freak low sound...
personally I would probaly contact the place where you bought the equipment, providing you have connected everything up correctly, it sounds like the amp is faulty
May 05, 2011 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Legacy LA770 worked for 2 10" subs but not for 1 12" sub
if the protect light is still on with all speakers disconected then you have overloaded the internal ic and blown it beyound its ability to reset
Jun 25, 2010 | Legacy Audio LA770 Car Audio Amplifier
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
My amp wont power both subs the same
you most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
Jan 12, 2009 | Pioneer TS-SWX310 Car Subwoofer
Car Audio & Video Logo
107 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
