Question about Samsung Heating & Cooling
I have a samsung split unit AQV12NSD and when it is in heat mode it shuts off and the green and red light blinks fast.
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
SOURCE: Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Posted on Oct 28, 2011
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
