Question about NAD T748 Home theater receiver with 3D-ready HDMI switching
How do i eliminate amp protection. Unit goes no further. Tried to unplug the unit & plugged back in but problem persists. Please HELP!!!!!
  • NAD Master
  • 15,557 Answers
This is a very ambiguous post. When you say that you are having this problem, what are you doing? Please post all the steps that lead to this error. There is no way to disable the amplifier protection circuit. If it senses a short (which could be a bad speaker) then it will be activated.
Posted on Dec 12, 2014
S-protection
This means that there is a short detected on one of the amp outputs. Try disconnecting the speakers from the back of the unit and power on. If fault still persists then likely you have a bad output ic or FET (transistor). If fault goes away after removing speakers then plug them in one by one to see which is the culprit.
Jan 12, 2017 | Audio Players & Recorders
Hello can u help me about my MHC-gzx55d sony hifi component, when you turn on the power, the screen display appear "PROTECT" what is the problem and what is the possible damage of my component. please help...
When it goes into protect mode it has been over loaded. Remove everything from the component and unplug the unit for a minute or two. plug it back in and see if it pops out of protect mode. If this does not work then you will need to do a factory reset or check the fuses on the inside of the unit.
Feb 20, 2015 | Sony Audio Players & Recorders
5200 printer error
From the Canon forums:
To try and resolve the 5200 error, please unplug the power cord from the back of the unit and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the error persists, the unit may require servicing to resolve the issue. Please click on the Contact Us link below to obtain further assistance and servicing options if needed.
This didn't answer your question or issue? Find more help at Contact Us.
This obviously a firmware error.
May 06, 2014 | Canon Black Pixma Ip 2702 High Quality...
My nephew was playing with the volume button and put the sound way up and then down 3 times. The sound then went off. There now is no sound whatsoever. I tried another speaker to confirm that the speakers...
Sorry to read about your problem, I hope this helps you out.
try to unplug unit. he might have blown fuse on amp drivers..or overdrove the amp circuit..and they have failed...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Audio Players & Recorders
Front panel not responding
Please perform the following steps:
1. Unplug the power cord from the unit.
2. Press and hold OK and Cancel buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, please replace the unit. From my experience repairing coast HP OfficeJet 7310xi is almost equal to the coast of a new printer.
:) Dr Tony
Apr 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My printer is showing error oxdo5do1od recycle power how can i over come that
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
How do i get the thing to not say protect
try factory reset by unplugging unit then hold down tuner button and video select buttons then plug in unit let display flash a couple times then release,if unit goes back to protect,you have a shorted power amp problems.
Apr 13, 2010 | Denon AVR-900 Receiver
Cant figure out why my protect LED indicators continue to go on.. Why is this happening?
disconnect speakers at the amp, turn unit on, if it goes into protect, it needs service. If it stays on, re-connect speaker wires without speakers attatched at the other side and test again. (make sure wires are separated and not touching metal!) if it stays on still, check speakers one by one, when it goes into protection, you have found your problem. Disconnect the bad speaker and test again. Process of elimination. It can only be one of three things. Internal amp problem(nothing connected and protection) wires(no speakers connected and protection) or speaker(s) (when speaker connected,protection) Hope this helps. If you need deeper troubleshooting with this issue, post a comment and I can help you further.
Nov 04, 2009 | Nady Systems XA-900 Amplifier
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
Sharp Air Conditioner
This is from Sharp's website...apparently an addendum to the instruction booklet. When you get E1:
Unplug. Press and keep pressing the On/Off button on the unit. Plug unit back in. Wait until unit beeps (about 5 seconds) then release On/Off button. Unplug unit. Plug unit back in.
You're good to go.
Sep 04, 2007 | Sharp AF-S120FX Air Conditioner
NAD T748 Home theater receiver with 3D-ready HDMI switching Logo
161 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
