Question about Garden
Why is my 1533 massey running sluggish no power
I have changed fuel filter , air filter, and I still have little power under pressure, when ever I go for power at all it boggs down. And I really couldnt see any leaks in the exust.
  • 15,756 Answers
If this is a diesel engine, you may need to have the injectors reset with an overhead or rack job. It could also be the injector pump.
Posted on Dec 12, 2014
Changed fuel filter on a massey fergeson 230 now it wont start
OOhh well I guess you've learned that its allways a good idea to prefill your fuel filter when replacing it , see my tip for priming diesel trucks (works for tractors too) , well sounds as if now you got air bound injectors (air compresses -fuel doesnot ) you will need to loosten (not remove!!!) injector lines at head till they bubble as you crank engine over , sometimes a quick method ive used is to " spray" paint thinner (mineral sprits) into air intake as I crank , engine should sputter and eventually start as injectors take over fuel delivery
Oct 06, 2016 | Toys
I have a 2001 Chevy Cameron 6 cyl. Ive changed the
Air filter, fuel filter, clean the throttle body, especially the back of the plate and where it sits in the throttle.
Aug 31, 2014 | Cars & Trucks
Mercedes clk 200 petrol 1999.guys I really need help quickly please. Only brought the car yesterday and already it's a goner. Driving home it was very sluggish. this morning again sluggish....
If it runs good in park or at idle but is slugish when you try to accelerate it is likely a fuel issue. I would start with a new fuel filter. When you press on the gas you need more fuel pressure and if the pump cant get more through the clogged filter you will get that. If it runs bad even at idle it is likely a spark issue and needs new plugs and wires. I would give it a good tune up - oil change, spark plugs (platinum or iridium), plug wires, air filter, fuel filter, PCV Valve and see how she runs after that.
Aug 11, 2013 | Cars & Trucks
1991chevy lumina starts hard, runs sluggish and then dies when put into drive. already replaced computer
Having replaced the computer, best thing you could do now is a complete tune up-new spark plugs, wires, distributor cap, rotor, air and fuel filter. Change the oil and check all fluids. Have the computer scanned for trouble codes. Check if your catalytic converter is blocked or clogged-if bad, they will plug up and stop the car.
Apr 10, 2013 | Cars & Trucks
My 2002 buick rendezvous will not go above 4000 rpm's. The engine loses power and feels like it is misfiring.
I would check into replacing a fuel pressure regulator its easy to install and it usually under 10 bucks.
Aug 18, 2012 | 2002 Buick Rendezvous
05 suzuki forenza running sluggish
Generally, fuel problems cause an engine to lack power.
If the check engine light is on you should have it scanned for trouble codes. The fuel filter should be replaced every 30-50,000 miles and the air filter checked at every oil change.
Jun 23, 2012 | Suzuki Forenza Cars & Trucks
Sluggish diesel engine
diesel fuel run in the winter is a lighter grade fuel to help is from freezing, and hard starting in the winter. You mnay have to replace the aircleaner. And may have to replace the fuel filter located on to of the engine, just under the air cleaner housing. The diesel fuel now sold in the summer is a little thicker and having a hard time getting thru the old fuel filter.
May 09, 2012 | Cars & Trucks
Starts ok but when put in drive it is sluggish and little power until speed increases, then drives at normal pace - but still slightly sluggish. Changed out Throddle Position Sensor, Air Control Valve...
try adding some lucas fuel treatment to your gas tank to clean those fuel injectors. sounds like you've done everything else i would suggest. hope this helps!!!
Aug 25, 2010 | 1995 Chevrolet Caprice Classic
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
