Question about Ovens
I just did a self clean the oven has cooled but the ovrn door wont open Please help
Pushed all buttons Nothing works
    Problem Solver:
  • 34 Answers
The oven must cool down somewhat before it will open
Posted on Dec 12, 2014
Frigidaire Oven door wont open after self clean cool down
Good Morning Marlyn Allen, thanks for your post!
Based off the information you have provided your Frigidaire oven door will not open after it has cooled down. I would hold down the clear or cancel button for ten seconds that should release the door. If that does not work I would perform a reset on your oven and you can do that by disconnecting the power from it for approximately ten minutes. You can also perform another self-cleaning cycle and before it starts cancel the self-cleaning and then wait for ten seconds and the door should release. If you follow these steps and the door does not open it could be a faulty door latch and that would need to be replaced by a technician. Best of luck! -Matt
Dec 12, 2014 | Frigidaire Ovens
Oven will not unlock after self clean
Unfortunately, the high temperature limit sensor probably failed during the self-clean cycle. The oven control unit will not receive the signal that the oven is cool enough to unlock the door without the sensor.
If the oven is cool, you can try unplugging the oven for a while and then see if the oven unlocks after power is restored. Pressing the Cancel button several times (or pressing and holding Cancel, depending on the model) may also work. Sometimes, starting a new cleaning cycle and then stopping it (and waiting for the oven to cool) will work.
However if the sensor has failed, the above steps are unlikely to work. You can try to move the lock manually. On some models, you can use a bent coat hanger to slide between the oven door and the frame and push the lock over. On other units, you might open the back panel and rotate the lock mechanism cam.
The oven will not work until the high temperature sensor is replaced. Sometimes the lock mechanism fails and that is what needs to be replaced. If the oven works, then look at replacing the lock motor.
I hope this helps. If your oven is under warranty, contact GE for the repair. Please add a comment with the model of your unit for specific information on the parts you may need.
Dec 29, 2013 | Ovens
I started the self-cleaning process on my GE electric oven last night. The process is complete but the oven door will not unlock. It sounds like it keeps running and running.
Hi
You can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if it wont work then press the CANCEL button for 20 seconds. If the issue returns then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | GE JTP15 Electric Single Oven
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked
if the oven cooled down and door still wont open unplug oven for 15minutes and see if that helps ive seen in many cases were the door had to be destroyed to gain access to the oven
Dec 30, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a try..Catriver...post back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
