Question about LG Audio Players & Recorders
I want to connect my LG sound plate 240 to my home stereo. What leads do I need
The unit is brand new, I have been told that this can be done. I know that I need an optical lead to connect the unit to my TV but can not see how to make the connection to my home stereo
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Stereo jack or phono leads from your tv to your stereo assuming you have a phono red and white aux input on the stereo
Posted on Dec 12, 2014
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
Hi, Can I plug my TV unit to the LG unit using phono leads for the sound. I have 'audio ou't from my tv, in the form on phono sockets, but I need to know if the LG unit will accept this for...
Hello
If your LG unit to which you wish to give the audio output of your TV has an input [Audio In] socket, you cah connect it with using phono leads. In most cases, the audio equipements will have audio IN sockets with them; some have an RCA socet, otheres have stereo type sockets which accept external audio signals. Look keelnly on the back side of your audio equipment and find out which type is there, and buy a phono chord to suit the need. If there is no audio IN on your audio equipement, there is no way to connect. OK.
May 19, 2011 | Televison & Video
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Audio sync issues between my stereo and my new LG 42PG20.
i have samsung home cinema and a lg 42lc2d.
the samsung has 6 speakers but all i can get to work 1 front speaker.
when i trythe speakers on test mode they all work with the test sound
could you please help me
best regards ron mcneill
Dec 25, 2008 | LG 42PG20 42 in. Plasma HDTV
Want to play my playstation thru my sa ht500 system
You will not be able to get full surround from your Playstation using this home theater system - if you use a red/white composite AV cable and connect it to the area marked TV AUDIO IN on the back of the Panasonic, you will be able to get stereo sound.
-Tha Mp3 Doctor
Dec 21, 2008 | Panasonic SC-HT500 System
Static noise from car stereo
change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
thats all i can think about
hope it works
Oct 28, 2008 | iLO XM-MP3-CD Car Stereo
No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
Oct 01, 2008 | JVC AM FM CD DET FACE CAR STEREO
Compatibility ps3 lg rz32lz50 tv
Sounds like your DVI converter. DVI provides picture only, no sound. If your TV has an digital optical input socket, it's best to connect PS3 to TV using this, then digital stereo sound should be yours..
Sep 06, 2008 | LG RZ32LZ50 32 in. LCD Television
Can not use the 5.1 surround sound system
stupid question, but you do have an optical lead connected? the hdmi will only produce stereo sound, you must also have an optical lead (aka tos link cable) connected to produce 5.1
Aug 12, 2008 | LG (GDR8164B) Internal DVD Drive
DHD ntx6408 subs
Voice coil has been blown open. Most likely alot of times what I do to test a speaker is connect it to a 9 volt battery. on and off and the speaker should bounce. If not speaker is blown. Plus this way you could save yourself lots of problems. If the speaker was shorted and not blown open. You would now possible have a blown amp and home stereo.
Jan 06, 2007 | DHD NTX-6612 Car Subwoofer
95 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
