Firnace burning tht fuse
Is burning fuse immediatly
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Clean dust out of it check all connections are tight
fuses up to 13 amp 3000w 1500w 5 amp 750w 3 amp
Posted on Dec 12, 2014
I have a 1990 chevy cheyenne c2500. my brake lights,parking lights and blinkers arent working and when i try to replace the fuse,it blows immediatly. what could the problem be?
What is the amp rating on the fuse that keeps blowing? I looked at wiring for stop lamps, 15 amp fuse. Unplug connector for stop lamp switch, see if the fuse still blows? Also see if anything at connector looks burned or melted.
You could have problem with fuse box, itself. Look at back side of fuse box, see if anything looks burned or melted.
Feb 28, 2015 | 1990 Chevrolet C2500
My slideout doesn't move, battery is new, changed inline fuse at battery, all other electrical seems to work
there is a momentary three way two pole rocker switch used to activate the linier motors that move the slide out. the most commin problem is they use a switch that dosen't have a high enough amp rating and the contacts burn out quickly. it is very importent to release the switch immediatly after the slide stops motion going in or out or these switches burn out very fast.
Jan 07, 2015 | Keystone 2009 Cougar Xlite 26BHS
Kia sportage 2005 central locking fuse burn when replacing it. Where do I start to find the problem
Follow the wiring after the fuse. look for burnt wires. pinched wires, failed locking solenoid wire to earth some where. Remember that the wire you are following will be live up to the point it earths out and over loads the fuse. Check all lock solenoids or the point where the wires go from the body to the door.
Apr 20, 2013 | 2005 Kia Sportage
The brake light fuse burns out immediatly when we press the brakes. brake lights not working.
Sounds like you have a short in the wiring for your brake lights unfortunately this on of those things that you have to take to an auto electric shop. Good luck some times those problems can be pricey.
Mar 10, 2011 | 1992 Lexus Ls 400
Why my headlight willl not work change the bulbs and they still wil not work what is the problem
most likely the fuse for tht particular headlight has popped or blown if so you will have to replace tht fuse...you will have to look at your fuse box and look up tht side headlight if not both headlight fuse and replace the fuse...after that your lights should work
Jan 12, 2011 | Pontiac Grand Am Cars & Trucks
Turn signals dont work
that could easily be just the fuse or the flasher unit. both are on the driver side under the dash
Mar 10, 2010 | 1991 Ford Tempo 4 Door
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
Fuel pump blowing fuses
replace the fuel pump relay, it is burned closed from the shorted fuel pump.
Apr 13, 2009 | 1993 GMC Jimmy
Transformer
what you need to do is isolate the loads that are on the transformer and put a amp meter on the transformer and read the amps while you put the loads on one at a time. the one that spikes is the one thats bad. You can put a inline fuse in to protect the transformer. A 3 AMP fusw qould be good for a 75 va transformer if its a 50 va you would need a 2 ampo fuse.
Jan 13, 2009 | Weather King 12AJA4801AH Air Conditioner
2000 ford excursion 7.3 diesel wont start
hi.check the start selenoid on the pass side of the engine in the engine valley it has 2 battery connections and a little wire it turns on the glow plugs the wire might be comprimised look for the wire chaffing or insulation rubbed off. does it blow out immediatly or over time?
Dec 07, 2008 | 2005 Ford Excursion
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
