Question about Vacuums
A sock is stuck in the hose of the truhepa vacuum...how do I get it out?
Taking the attachments off...but it's stuck in the coiled part of hose.
    Master:
  • Vacuums Master
  • 792 Answers
HI, it's Jim from Crucial Vacuum!
Turn the vacuum off first and then try stretching the hose out entirely to release any clogs. A handy way to unclog hard to reach spots in your hose is to use a broom handle, or coat hanger. With the coat hanger try and use a plastic one to avoid tearing the walls of the hose.
You can purchase high quality replacement hoses and parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Dec 12, 2014
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Wire coathanger with hook or broom handle with hook on
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Sock stuck in hose midway. Unable to getit out with wire or brrom handle. Is there a way to take hose apart at either end.
If the sock is midway, taking either or both ends apart won't help. Take it to a vacuum repair shop and ask them to try to unplug it. You may need to buy a new hose.
Feb 22, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
Bissell 35962 Cleanview Bagless Revolution Upright Vacuum hose is clogged with sock where hose meets handle attachment. Attempted to use broom handle to push back through suction opening. Sock is...
If you have access to a small sink "snake" used to clear clogs in sinks, you might be able to use it to "snag" the sock and pull it out. Needs to be a metal sewer snake so that you can tug on it if and when it snags the sock.
Sep 05, 2010 | Bissell 35962 Cleanview Bagless Revolution...
I got a sock stuck in the hose how do i get it out?
Take a metal closthes hanger and undo the hook end from the spiral at the base of the hook, leave the hook and the coil that held the hanger together as is and straighten the rest. Put the spiral end of the hanger into the hose, when it reaches the sock twist the hanger to screw the spiral into the fabric, not too far, only a little. If you have enough grip on the sock, it should pull back out. You may have to try several times until the sock pulls free. Good luck.
Feb 04, 2010 | Kenmore Vacuums
When i use the power brush attachment, dust flies out of the hole that the hose attaches to... is there a way to prevent this or is it just how it works?
this is the nature of this vacuum, the roller will always spin, when the vac is turned on. You can either cover wit tape or maybe find a sock to put in it (remember to remove sock) when putting hose back
Oct 12, 2009 | Hoover U5507900 Elite Rewind Bagless...
So... my friend sucked a sock in his maybe '07 bissell.
its there and is stuck itll take some time and patience to get it out its probally stuck at the sammlest poit pf suction .and the coat hanger and such is really the only way unless you wanna tear it down?
Jul 06, 2009 | Bissell 2600 Sweeper Vacuum
Any tricks to putting on a central vacuum hose sock? The last one took me 4 hours and I'm sure there must be an easier solution. It has no zipper.
Send it back and get one with a zipper. :) Okay did it come in a tube or with a tube? They are really necessary when putting a hose sock on. You first want to put the hose sock on the tube. You then slide the tube over the hose and take the hose sock off at the end. Tie the hose sock securely in place and start pulling the tube over the hose. The sock will slide off the tube and onto the hose as you go.
Jun 08, 2009 | Electrolux Central Vacuum
Ive got a sock in the tube
remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Nov 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Sock stuck in hose
Yes there is a small clip on the purple/yellow part on bottom of hose. its hardly an inch thick pll back on the tab and up on the hose
Oct 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stuck sock
first off how did u get the sock that far..lol but yes it (can but it is a pain and u chance tearin the hose but if ufeel like u have to better get a roll of duct tape just in case)but i would try the coat hanger a little more put a bend at the very end of hanger hook the sock and pull
Dec 30, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
