Question about Casio Watches
HOW DO I REPLACE BATTERY ON CASIO CHR-100-1V HRM
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
My watch strap pulled off the watch while gardening. Where can I get it repaired in Auckland NZ. It is a Casio Sport CHR 100. The plastic supporting the pin appears to have sheared off
Go to their web site "Casio.co.nz", click on "support"and then choose "service agents".
You will then be presented with a map from which you can find your nearest service agent.
Feb 14, 2010 | Casio Sport #752V Watch
Can't pair garmin forerunner 50 with hrm and food pod
First you have to assume the battery that comes with your HRM would be new - keep in mind that it may be stored in the warehouse for many moons.
Given that, open and take out the battery - that should make a hard reset on the HRM itself. Restore the battery and try the manual pairing again.
The heart icon should pop up again.
Otherwise, you have to suspect the battery is low and need to be replaced.
Good luck
Jun 05, 2009 | Garmin Forerunner 50
I bought a Forerunner 50 with HRM and Footpod. Initially the footpod wouldn't work, but HRM would. So changed the battery and footpod is fine. However, HRM now won't work. Just replaced the battery in that...
I had a similar problem. First my hrm worked and the footpod did not. Then I tried to pair manually (for the umpeenth time) when the hrm was too far away, and I lost that pairing, and it still didn't find my footpod. Then I wet the hrm sensors and tried pairing again and then it picked it up. Finally, I switched batteries in the hrm and footpod and then it picked up the footpod. Now I'm headed to the store to stock up on batteries. Kinda upsetting that I have to buy batteries when I just got the thing, but probably costs less than the postage for sending it back!
Feb 21, 2009 | Garmin Forerunner 50
Heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Feb 20, 2009 | Garmin Forerunner 50
Can`t pair Garmin Forerunner 50 with footpod
I've been having the same problem. I couldn't pair my footpod, but my heart rate monitor was working. I've only had the 50 for about eight weeks.
I reset the watch, holding view mode and Start/Stop at the same time.
This didn't do any good.
I swapped the battery in the HRM with that in the foot pod. The foot pod synched the HRM didn't.
Solution duff battery. I'd change yours it will probably do the trick.
Hope it helps
John-Paul ( AKA OldGreyWizard)
Jan 10, 2009 | Garmin Forerunner 50
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Watches Logo
107 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
