Question about Yamaha Rx1 Warrior Stator Magneto Generator Engine Motor Cover 03/04/05 2003 8fa
03 rx1 no start, i have power to starter, no dash lights or spark? motor does turn over.
    Habit-Forming:
  • 5 Answers
Starter could be froze. I had one and if I hit it with a rubber mallet it would turn. Also check the juice of your battery it might be too weak.
Posted on Dec 12, 2014
Motor don't turn nothing dash lights and head lights 1985toyota pu
Do the gauges and warning lights work with key on? If not, check fusible links, AM1 for ignition key power. If the gauges/warning lights work, the key switch has power, so you can follow it to the starter solenoid. The start wire out of the ignition switch is a black/white wire, this is the hot wire to the solenoid, and only has power when key is held in start. With automatics, there is only one switch-a neutral start switch- between the ignition switch and the solenoid on the starter .
With a manual transmission, the black-white start wire goes to both a starter relay and a clutch start switch (on the clutch pedal), those two work together to send the power on to the starter solenoid. So, no crank, good battery, power to key, follow the black/white wire, the start relay and the clutch switch, to the starter solenoid- a hot wire there turns the starter motor on.
Mar 17, 2015 | Cars & Trucks
Hi my starter motor won't fire when I turn the key. All dash lights light up, Battery is good, Starter motor works if I short it manually engages & turns the motor over. I have made sure it is par
check the wire from the starter to the ignition switch as ot requires power from the switch in the start position to energize the solenoid of the starter.
Jan 01, 2015 | Holden Cars & Trucks
Corsica won't start,
Start by checking the battery cables for corrosion at - to motor and + to battery. If all cables are good It will be the starter. the lights dimming while turning the key is normal. PS you can also give the starter a few good whacks with a hammer then try to start it.
Jul 05, 2013 | 1993 Chevrolet Corsica
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
Turn the key, heard starter solenoid pop, clicking like there wasnt enough power from battery. Replaced battery, turned key, and all the lights on dash went out, unhooked battery checked connection, then...
Either the cable from the battery to the starter is shorted or the starter motor itself has a dead short or the starter relay has a short. As soon as the key is turned, the starter relay is closing and all the power of the battery is heading for the short to ground. That's why the power seems to be lost.
Feb 09, 2011 | 1993 Mitsubishi 3000GT
2003 yamaha rx1 snowmobile my engine light is
Go to this site and get yourself a manual, it should contain the information you require plus a lot more:
http://www.yamaha-motor.com/sport/myyamaha/prompt/L3Nwb3J0L3NlcnZpY2Uvdmlld21hbnVhbHMvdmlld21hbnVhbHMuYXNweD9scz1zcG9ydA==/Owners%20Manual/starthere.aspx
Feb 10, 2010 | 2003 Yamaha YZF-R1
My 03 rs 250 wont start
it sounds like , when you where adjusting the shift ,it might be off a little and the bike thinks it is still in gear ( false neutral ),maybe readjust the shifter and see.worth a look.
Oct 09, 2009 | 2006 Aprilia RS 125
My 03 impala wont start up ..wen i turn the key jus clickin noise
if the clicking is repeated with out you releasing the key then the battry is in need of charging or replacing, if its a one click each time then the starter motor is faulty.
May 13, 2009 | 2002 Chevrolet Impala
Yamaha Rx1 Warrior Stator Magneto Generator Engine Motor Cover 03/04/05 2003 8fa Logo
88 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
