Question about Galileo Optics
I cant get my talescope to wirk
Not sure what model it is
How can i get my antenna to wirk for a curtis model tv.
Connect the antenna; and then switch ON the set. What else?
Aug 21, 2016 | Curtis Televison & Video
My lg flatron n2294a - PM displays an "out of range" message and won't wirk with my ps3 when using the hdmi or AV option. Whats wrong?
Your resolution on your ps3 may be too high for the tv to display. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Apr 01, 2013 | Computers & Internet
CANT GET TENSION SET AND ITS SO FAR OFF DONT KNOW WHERE TO START....vogue stitch old..model.label on back says model 1300/1500 or mercury model 704
try www.sewusa.com repairs page for troubleshooting help. start by cleaning and oiling machine. then wind a new bobbin and put in a new needle. load bobbin into bobbin case and ensure thread goes into tension spring. now dangle bobbin case by holding thread tail, bobbin should hang in the air but release thread if you pull it. adjust the tension screw on case 1/4turns only and test again until you get it tight enough to 'dangle'. now load bobbin into rotary hook of machine and thread top. now test sew and adjust top tension in small increments if neede to balance the stitch. but if top tension is wirking okay then 4-6 range should be fine.
Aug 24, 2011 | Sewing Machines
WIRELESS SWITH RADIO ON OFF IS NOT WIRKING
Does your computer have an ON/OFF button (or slider) for the wireless, and a separate ON/OFF button (or slider) for BlueTooth?
Try each of the 4 settings:
* OFF/OFF
* OFF/ON
* ON/OFF
* ON/ON
Click Start
Click Control Panel
Click Network Connections
Click with the SECOND (usually the RIGHT) mouse-button on the wireless-adapter.
Click ENABLE.
May 14, 2010 | Dell Latitude E5500 Laptop
My Whirlpool is in the garage. It's cold outside (below 5 degrees C) will it work? Model FRUU36AF20
may not work newer frig's are no longer designed to wirk in ambient temps lower then 60 degrees, gotta love energy efficency
Jan 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
EB Model MP8100GB Doen't work even after charged
When I plug my ipod nano on the computer it wirks but when I touch it while it's charging it stops and when I take off the charger it won't turn on and it keeps showing an apple on the screen than it's off like it
s on then off on then off , apple then off apple then off. WEID
Sep 23, 2009 | Audio Players & Recorders
Still no one has helped me with my problem . . .i.explorer
Go to www.yahoo.com and download I E -8.0 from Yahoo cost free
i am sure it wil solve ur problem.
mail me if it wil help u
Jun 16, 2009 | Microsoft Internet Explorer 8
No output from my generator
check breaker, your outlets should be like a gfi
May 21, 2009 | Coleman Powermate Premium Plus 6250W...
Pls my system window vista is not compatable with Arabic language, and it doesnt allow some soft wares 2 install pls help me out now
you will need to download the arabic language surely if you have an it still dont wirk then im unsure
Dec 18, 2008 | Computers & Internet
My cam wint wirk
hi,
can u plz send the correct modem and make of the cam ?
and is there any thing obstructing the cams lense ?
chk that !
this problen occurs due to 3 cases,
1. Driver of the cam is not installed properly
2. Windows files are missing.
3. The Cams CCD or CMOS sensor is damaged or broken.
Mar 10, 2008 | Genius VD3000022 Webcam
Optics Logo
59 people viewed this question
Top Galileo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
NOEL
NOEL
Are you a Galileo Optic Expert? Answer questions, earn points and help others
