Question about HP DeskJet 5550 InkJet Printer
Peed problem Hi , My DJ5550 is feeding the paper , passing the paper sensor , the voltage of the sensor changing . but the paper stop randomly any where and the paper is flashing .Do you know a way to download a firmare for that model? thanks
  • barucha Nov 11, 2007
    The paper led on the panel flashing ..
  • 148 Answers
Visit the manufacturer website
Posted on Mar 17, 2008
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
How do i change paper feed wheels
If you have tried to clean the paper pickup rollers and you are getting your paper ejected late from the printer,chances are that the whole copier needs to be cleaned. If you open the left-side door,you will notice that there is a Grayish roller or sometimes black. the tend at also get coated with paper dust. This Glazing will also reduce the time the paper passes from sensor to sensor. Everything works in time and unless you have reached the point of 200,00 copies printed,it a matter of cleaning everything to include the optics. Also the Delivery roller usually does not need to be replaced. The late paper feed is a sign of Glazed, dirty rollers.
Jun 05, 2014 | Sharp MX850RT paper feed and delivery
Paper jam signal
I know your copier has sensor
1. Paper feed sensor in cassette
2.Paper feed by pass tray sensor
3.Transfer unit sensor
4.exit sensor in fuser unit
5 Paper exit sensor duplex unit
may be any sensor displace or broken
its open
please check it and fix problem
Jul 14, 2012 | Canon imageRUNNER 210S Copier
Hi my this model of printer is not pulling the paper..how to solve it?
Hi, Manually you can feed the paper right? top feed or front feed. LQ 300 has a sensor for paper feed, if it cannot feed paper automatically there could be something wrong with the paper feed sensor. Sensor of which is just a switch that once the paper pass, it will trigger the switch. If you can open up your printer, you can check the switch if still working. If you manage to locate the switch take out the switch and have check by ohmmeter tester to check the continuity. It sound technical but you can ask help.
Jun 21, 2011 | Epson LQ 300+ Matrix Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Paper feeds into printer 1/2way, stops, check paper light flashes
Yes, there is a sensor on the right side of the carriage that points down at the paper, you use a Q-tip moist with water and wipe the underside of this sensor, you may need a couple since quite a bit of ink sprays onto this sensor.
Jul 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
HP DeskJet 5550 InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
