Question about Sony Cameras
Recently I bought, (new), a Sony DSC RX100M3 camera and I am very pleased with it. I want to use my camera in all weathers, (rain, snow, etc., but NOT under water). Can you recommend a waterproof ca
Obviously the case must be big enough to accommodate the camera, with its zoom lens, and it must be possible to operate the controls
  • 28 Answers
SOURCE: DSC-W90 Sony Digital Camera - Lens Error
Sorry man, I think you're out of luck. Most likely nothing you can service, maybe a professional can fix it though. Still under warranty? Good luck.
Posted on Nov 09, 2007
mcomijohns
  • 477 Answers
SOURCE: Sony DSC-H9 error 61:00 (when lucky enough to get that far....
Camera need to be sent back to where you got it for replacement.
http://www.digitalcamrepair.com/self_diagnosis_page.htm
Posted on Apr 26, 2008
Rammsteins
  • 300 Answers
SOURCE: sony Cybershot DSC-W150-turn power on, lens zooms
Hi!
It's probably stuck focus. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Posted on Jul 29, 2009
samanthaj08
  • 570 Answers
SOURCE: HI. Is it possible to disassemble a Sony DSC-V3?
http://www.fixya.com/support/r3771170-phone_water_damage
As for the sand, I'm not sure how that would be removed.
Posted on Jan 08, 2010
  • 11967 Answers
SOURCE: MY lens doesn't go back in?? says to turn camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 18, 2010
Sony model no. DSC S650 - display shows a crack and a bid black m
mam i would like to suggest you to send it to repair service because it has a physical damage. much beter to go to sony repair service to give you some benefits and compatibility with your device parts.
thank you for using fixya
CHARCOIS
Mar 04, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Sony DSC W40 , screen appearing black
ther should be a small button below the menu botton try pressing this a few times this a energy saving device .hope this helps.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Nov 18, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Sony Cyber-Shot DSC-S30 memory stick
Without being accusatory, it is likely that something bad happened to the camera (a drop, and accidental liquid spill, etc.). But the bottom line is that it sounds like you did all the proper things, and I'm sure you tried a full charge of the camera's battery. The good news is that a quick check of Amazon shows this camera to be fairly easy and cheap to replace at this point. Its listed as a 1.2 Megapixel camera which by today's standards is low enough in resolution, that you probably can replace it for about $20. Sony may be willing to service it, but I'll bet replacing it will be cheaper. Sorry to be a bearer of less than good news.
Jul 01, 2017 | Sony Cyber-Shot DSC-S30 Digital Camera
Sony Memory Stick Duo Adapter
When you download to the computer, what program do you open with? Try not using the auto-open feature, and open direct from new device in "my computer".
Ed
Dec 11, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
SONY CAMERA DSC-P52
have you tried formating the memory stick on the computer and see if that works? how did you put the pictures on the computer? via the USB that came with the camera? or did you use the memory stick and put it into the camera?
Nov 11, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Nov 09, 2007 | Cameras
Problem
well, i just chcked my camera, and you have the right type....it could be the battery is just bad, though i don't know how to check this without trying it in another camera.
Oct 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
All weather
The Olympus Stylus 410 Digital camera will not be damaged by water splashed onto it from any direction and can be used outside in adverse weather conditions such as snow or rain. The Stylus 410 Digital camera is all weather, not waterproof, and cannot be immersed in water. It is designed to operate at ambient temperature 32?-104?F and relative humidity of 30-90%.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Cameras Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
