Question about Sony Audio Players & Recorders
Sony subwoofer - Sony Audio Players & Recorders
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Feb 15, 2015 | Sony STR-DE597 Receiver
How to improve poor bass
WWW WELECTRONICS COM SONY MHC WZ80D WZ 80D 80 HOME THEATER MUSIC SYSTEM...
Sony 12 Single Voice Coil 4 Ohm Subwoofer with Enclosure
Adding a subwoofer to your system will enhance the bass response. Sony lists the SA-WZ80 as an optional add on subwoofer for your system, I could not locate it on the web. I added another one of Sony's subwoofers that may work with your system. I suggest you go to an electronics store with the Sony MHC-WZ80D System manual and ask about subwoofers for your system. It does not necessarily have to be a Sony product. Best Buy may be able to help you.
May 19, 2014 | Sony MHC-WZ80D System
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
What do i need to install a subwoofer
Here's what you need:
1) An enclosure for the 8" subwoofer.
2) 8" subwoofer.
3) Amplifier to power the sub.
4) Amp wiring kit.
Your Sony has two sets of preamp outputs so make sure that your wiring kit includes a set of RCA's.
Mar 24, 2009 | Sony Car Audio & Video
SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Sep 25, 2008 | Sony SA-WM500 Subwoofer
Sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Jan 14, 2008 | Sony SA-WX90 Subwoofer
Subwoofer power but no sound
sony suks.is it a powered sud?if not take any battery and touch the leads on the speaker if u get a sound speaker is workig.
Dec 06, 2007 | Sony Xplode P5 Turbo Subwoofers Car...
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
