Connect acoustiqbluetoothspeakertoandroidphone
    Sergeant:
  • 399 Answers
Turn on Bluetooth on your phone (Settings-->Bluetooth) and then follow the set up instructions that came with your speaker.
Posted on Dec 19, 2014
What wires do I connect to a trombetta 974 1215 011
basic installation, use only if you feel it is related exactly to basic setup, refering to action you take with hooking up wries....
Wiring Diagram
1. Connect Load (A) to High Current stud (B)
2. Connect battery positive (C) to fuse (D)
3. Connect fuse (D) to High Current stud (E)
4. Connect Switch (F) to Coil stud (H)
5. Connect Ground Wire (J) to Coil stud (K)
Jun 24, 2014 | RVs
Cant connect to wifi
How is it not able to connect to wifi?
-Not able to see the wireless network.
-Not able to connect to the wireless network.
-Was able to connect before but now it is not able to connect.
Have you tried to connect it to another wifi connection?
Ref: http://www.nintendo.com/consumer/wfc/en_na/ds/wrInitialSetupHelp.jsp
Dec 17, 2012 | Nintendo DS Lite
Linksys WRT160N router problem
go to control panel--network and internet--n/w and sharing centre---manage wireless n/ws---remove all wireless n/ws u see there including ur n/w name......then click start--connect to---connect to ur n/w typing proper encryption keys
May 30, 2010 | Linksys WRT160N Wireless Router
Connecting my phone to my PC
Nettworking wizard will be opened after you are able to connect the phone. For that you must start PC Studio and select Connect. There you will fine various means to connect. Select USB and connect. Or BT connect. Then select a comm port one by one and try to connect. One of the comm ports will accept the phone and connec.
Aug 22, 2009 | Samsung SGH-U600
How to install a clutch?
the mechanic should place or connect the clutch pedal spring to the clutch pedal .connect the push rod to the clutch pedal.then connect the push rod to the clutch master cylinder then refill the clutch master cylinder .by means of pressure tube connect the clutch slave cylinder .then connect the clutch slave cylinder to the push rod .And the push rod connect it to the clutch pork. the clutch pork connect to the spring. then connect the fly wheel , the clutch linning ,the clutch disk ,the release bearing,then the clutch pork to the transmission shaft . then connect the transmission assembly.And you can goon with your date.
Aug 03, 2009 | Volkswagen Jetta Cars & Trucks
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
HOW TO CONNECT PRINTER WITH PC?
first you have to connect with the power
then use the printer cable to connect the printer with your pc.
If you can mention the printer i will tell how to connect with the pc
Normally in new printers they use the USB cables to connect printers.
OR the parallel port to connect printers like dot matrix ( in this port there are only one port are in the behind the CPU it is a normally biggest connector )
Nov 07, 2008 | Epson LX-300 Matrix Printer
Computers & Internet Logo
David Payne
David Payne
