Question about Generac Power Systems Generac 5951 Nexus Advanced Wireless Remote In-Home Monitor
What do you to to restore radio signal to a Generac 5951 wireless remote monitor
My wireless monitor is showing no signal
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Press the pairing button
Posted on Dec 12, 2014
How do I restore radio signal
You need to power down the tranmitter by unplugging it, wait a minite and plug it back in. The transmitter is the black thing on the back of the generator. You have to remove the black cover around the controller to access it.
Dec 12, 2014 | Generac Generator 5951 Nexus Advanced...
How do I adjust squelch. Squelch is locked on
I suspect you have it in the continuous monitor mode so follow the directions for getting back into the automatic squelch mode.
AUTOMATIC SQUELCH: The FRS is equipped with an automatic squelch circuitry filtering out weak transmission and unwanted noise, usually caused by terrain conditions.
MONITOR:
- This feature turns off the automatic squelch feature, either momentarily or continuously. It helps in receiving signals to its maximum range, but may pick up static signals, too.
Momentary monitor:
- Press the MON button; the monitor symbol will appear.
- Release the button to restore the automatic squelch.
Continuous monitor:
- Press the MON button for more than 2 seconds until a beep sound is heard. The monitor symbol will appear.
- To restore the automatic squelch, press and release the MON button again.
NOTE: You cannot transmit when the Monitor feature is activated.
This comes from the manual I found on-line at:
http://www.michaelknows.com/electronics/walkie-talkie-manual/
Oct 26, 2013 | BellSouth 1011 (14 Channels) 2-Way Radio
Jensen VM9314 remote does not work...not the battery
Your remote may be faulty.
I would either take it to an autozone and check it is working there ( they have an infrared remote check on their keyless remote battery center that will show the IR signal being sent).
OR
you can point it at almost any of the security cameras in production and view the 'IR flashlight' on the video screen/ monitor.
If the remote is in fact not producing a light , I will assume the unit needs replacement batterys or remote.
Alternately , you can disassemble the remote and check the IR emitter with an Ohm/Volt meter.
should the signal be present on the meter and yet no 'light' is being emitted , then replace the emitter with a new one (avail. at radio shack...)
If the remote does emit a signal , chances are the reciever is bad.
My Jensen came with two remotes... did you try the other one ?
Oct 04, 2011 | Jensen VM9510 Car DVD Player
No lights are lit on my Nexus Remote monitor for my Generac standby generator. The generator is working - just went through the testing cycle. Batteries are less than 6 months old. Maybe I need to...
batteries only last about 3 months on these units. make sure you are within 20 ft of the generator and put in new batteries. The green light will blink is a minute or so.
Apr 23, 2011 | Generac Power Systems Generac 5928 Nexus...
When conneting Acer Aspire 5810TG to a Samsung LCD LE32M6. The Samsung LCD shows 'no signal'.
On most laptops, you need to turn on the external monitor connector from a function key on the keyboard. It doesn't automatically sense you've hooked up the other monitor. On your model, hold down the Fn key and press F5 to switch the external connector on. Here's the page from the user guide with the key combinations you might find helpful:
Dec 17, 2010 | Acer Aspire TimelineX 5820T-5951 Notebook
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Jan 01, 2009 | Dell Inspiron 6000 Notebook
Wirless radio switch for Toshiba 1410 S173
If it ain't the WiFi Antenna on switch (right side, towards the front), then it's an incompatible WiFi card (assuming it's just been added to the system).
Nov 26, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Remote Control Extender from Radio Shack
To determine if your PC will simply not connect or if really your wireless AP/Router, please download NetStumbler, install and run. The software will determine if there is an AP within your immediate area (including yours/high signal strength), if there is & it is yours, then it is configuration problem, it none or some but weak (low signal/not yours) then it is a hardware problem and would most probably require replacement. Most of the time, the cost/time of repair would make the purchase of a new one more reasonable. If your Wireless Ap/Router was detected by NetStumbler, then perhaps what you need is to re-configure your system/set-up again.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional; information.
Good luck and kind regards.
Nov 16, 2007 | Radio Shack Wireless Remote Extender...
Generac Power Systems Generac 5951 Nexus Advanced Wireless Remote In-Home Monitor Logo
330 people viewed this question
Top Generac Power Systems Home Security Experts
Lawrence Oravetz
Are you a Generac Power Systems Home Security Expert? Answer questions, earn points and help others
