Question about Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
It doasnt swich on
  • Megersa Girma Jul 19, 2016
    how we solve canon 2202 e000-0000 problem?
  • kagimu joseph
    kagimu joseph Jan 13, 2017
    hello megersa sorry for that error but have you tried to check well on the machines fuser unit because that fuser film might be worn out or not rotating well
    The fixing film unit is faulty. The main thermistor has an open circuit. The fixing heater has an open circuit. The main power supply PCB is faulty. The DC controller PCB is faulty. To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
    Remedy
    1. Connector Is the connector of the fixing assembly connected? a. main power supply PCB (J8) relay connector heater b. DC controller PCB (J320) relay connector thermistor NO: Connect the connector. 2. Fixing film unit (thermistor) Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connector (4-pin) of the thermistor for electrical continuity. Is it W (open)? YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit. 4. Main power supply PCB, DC controller PCB Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB? Main heater: between J8-1 (FSR1) and J8-5 (FSR COM) Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM) YES: The heater drive power supply is faulty. Replace the main power supply PCB. NO: The thermistor control mechanism is faulty. Replace the DC controller PCB
    Master:
  • Canon Master
  • 553 Answers
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Posted on Dec 25, 2014
  • 12 more comments
  • maabgeedi Jan 19, 2015
    How can i enter the service mode
  • sahoo_sanjay Jan 20, 2015
    PRESS add functions > 2+8 > add functions > Copier > Function > Clear > Select ERR and hit ok a couple times for good measure, reboot machine(power OFF & ON).
  • maabgeedi Jan 21, 2015
    Dear
    Dear it dont have the keys 2 0r 8 i can't access the service mode
  • sahoo_sanjay Jan 21, 2015
    Dear
    Yep bro did you get any solutions
    Dear its a touch panel key board. Pl. do touch on the marks COPIER + FUNCTION + CLEAR (select) + ERROR. t will be better to upload the panel photo. I remember there is a numeric key board. Thanks..
    Thank you bro i got it entering service mode.
    and your answer worked thank you dear.
    Done great. thanks.
  • coby Mar 02, 2016
    My Canon 2202n is showing Error Code E000-0000 how to solved it please reply sir in my email= cpuunlock@gmail.com
  • richmond john cudjoe
    richmond john cudjoe May 13, 2016
    My Canon 2202n is showing Error Code E000-0000 how to solved it please reply sir in my email= richmondjohncudjoe304gmail.com
  • Tanmoy Mandal
    Tanmoy Mandal Nov 29, 2016
    My Canon 2002N is showing Error Code E002-0000 how to solved it please reply sir in my email= tanurajamandal@gmail.com
  • Betty Mengistu
    Betty Mengistu Jan 13, 2017
    hi would you please send me how to solve E000-0000 for the copier IR 2202
    thank you
    New Friend:
Photo copier 2202 turn the main power off and on E000-000
Posted on Oct 06, 2015
    Habit-Forming:
  • 48 Answers
E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now.
Fixing unit is a necessary part of every photocopier and laser printer. It applies high temperature and pressure to melt the toner particles into the fibers of the copy paper. The temperature of a fixing unit must be sufficient to adequately melt the toner particles. Usually, an electronic component called Thermistor is used to measure and control the temperature. If temperature does not reach to a specific level within a predetermined time, it sends signal to the main control board to stop the machine and display error code.
Fixing error codes should be reset by a professional only. Thermistors, heater lamps, thermostats and other parts must be examined carefully before resetting the E000, E001, E003 and E007.Failure to do so may result in severe damage.
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Posted on Jan 13, 2017
SOURCE: I GET ERROR CODE E000840-0001
solution E000840-0001...????
Posted on Jul 26, 2011
mossad010
SOURCE: Canon iR 2016i DOWNLOAD STANDBY Error.
download standby
Posted on Mar 01, 2012
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
  • 1040 Answers
SOURCE: canon ir 3300 display shows error E000003-0000
RESETTING CODE E000003-0000 ON CANON IMAGE RUNNER 5000 COPIER
Posted on May 20, 2010
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Fixing unit problem.Main thermistir,fixing heater.main power supply or DC controller .To reset error u have to execute it in service mode:COPIER<FUNCTION<CLEAR<ERR
Jul 28, 2015 | Canon Office Equipment & Supplies
Canon iR2202
Hi
Please follow the below procedure to enter Service Mode
1. In standby mode, press the "Settings/Registration" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
COPIER> FUNCTION> CLEAR> ERR; and then turn OFF and then ON the power.
Jul 24, 2015 | Canon Office Equipment & Supplies
How do I solve error E002-0000 canon IR 2202 copier ?
Refer to documentation under Troubleshooting for a listing of the error you have mentioned and repost your question i can help
Jun 25, 2015 | Canon PIXMA Office Equipment & Supplies
Canon ir 2202 error code e0141-0000
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR2200
Jun 19, 2015 | Canon Image Runner 2022 Copier
How to solve error code 000 on canon ir 2202 photocopy
http://www.thecopiernetwork.com/showthread.php?124083-canon-ir-2202
Feb 12, 2015 | Canon Office Equipment & Supplies
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
Dec 03, 2014 | Canon Office Equipment & Supplies
Canon ip4700 error 6502
Ink tank position sensor error [6502] - Platen unit (QM2-2202) - Logic board ***'y (QM2-2670)*1
Jan 27, 2010 | Canon Office Equipment & Supplies
5,749 people viewed this question
old marine
old marine
