Question about Indesit Washing Machines
My indesit WIB111 is full of water & clothes. how can I manually drain the water out?
The drain cycle, it goes through the motions but it doesn't drain the water & the red & green lights flash when it finished
    Problem Solver:
  • 14 Answers
You probably have a blocked drain hose - the most common cause is a coin or a button but sweetie wrappers & paper are just as bothersome. Turn off the machine & unplug. Pull the machine forward so that you can access the rear. The drain hose is at the bottom of the rear of the machine and is held in place by a very strong spring-loaded clip or else a jubilee clip. This needs to be removed & will result in the water inside the machine & hose draining out so make sure you have plenty of containers & cloths/towels etc to catch & mop up. The blockage is usually located just inside the hose. Remove anything you find. Also check the hole on the machine where the hose attaches. Re-attach hose. Clean up, put machine back and switch on. Also check filter for clogging (see manual). Run machine on rinse & spin cycle. Hopefully that should do it. Good luck.
Posted on Feb 20, 2015
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Put the machine in the emergency drain mode press the start button when it stops
http://www.manualslib.com/manual/76755/Indesit-Wib-111.html?page=13#manual
Posted on Dec 12, 2014
Wib111 drains but not spinning, also repeating cycle
Check your fault codes. I have had to raise the discharge hose to 1" to 1 1/2" above the back of the washer, then connect to the drain tube. Height of the discharge hose can cause cycle to not operate properly, like fill and drain at the same time and won't cycle properly.
Jun 20, 2013 | Indesit W 123 Front Load Washer
Indesit wib111 leaking from pump
This that unscrews is a filter cover, it does have to come out and will be restricted by something thats blocking it, without being too forceful it will have to be removed so the "catch area" can be cleared of objects, like pins and maybe a sock, then the cover can be screwed back in and made secure to stop it leaking (engineer of 20 years experience)
Aug 29, 2012 | Indesit Washing Machines
Fischer & Paykel washer will not drain. What do I do?
take clothes out,check the hose for is it blocked or kinked put a clothes hanger in hose and see if you can un-snake any thing out,then put draino-max jel in washer and let it set for about 2-3hrs,see there may be hair blocking the pump were it drains,this stuff work great for front-loader so let it sit.then try putting on drain it may take a few times,the when it drains,run washer on full cycle no clothes hot-water let it go through a full wash cycle etc.
Aug 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
