Question about Linksys Wireless-G Broadband Router
Goodday how can l configure wireless -24GHz broadband router
L want to set up the router for wireless connections
    Problem Solver:
  • 8 Answers
I recommend you consult the router manual. If you don't have it, you can d/load it from linksys. For most routers setting up wireless is not too hard, and it's a question of putting the right values in the router set up - which you enter by putting in the right ip address and then the right username and password. Again, get this information from the linksys website. Good luck.
Posted on Dec 15, 2014
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How can i configure wireless broadband router 2.4
Hi Friend,
In order to configure the wireless settings of a router please follow the steps:
1.Open the router page (192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.On the router page click Wireless and fille the sections as mention:
Wireless network Mode-Mixed
Wireless network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID Broadcast-Enable and click Save settings.
4.Click Wireless settings and Select the security mode as WEP
WEP encryption-64 bits 10 hex digits
Key1- enter 10 digit or 10 letter password(like your telephone number) and click save settings.
5.Click Advanced Wireless Settings and fill these sections
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click save settings
Turn off the router for 30seconds and then turn it on. Your network is now secured and you can try to connect your wireless devices.
Regards
Chiranjeet
May 19, 2010 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
No wireless connection :(
If you have your broadband configuration info written down, you could try resetting your router to the factory default settings and then re-configure it.
For most broadband connections, the default settings will work OK, but you should configure your router with a secure administrator password and wireless key.
The user manual for the router as well as configuration software can be found here:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Feb 04, 2009 | Belkin (F5D7230-4) Router (587009)
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Wireless set up for ntl
hey thats easy man dont worry, if you have a existing broadband at home, just connect the broadband to your router, then connect the cable that comes up with the router to your laptop. then access the web configuration of the router, the ip address is usually written in the manual. then configure it with the settings that your Internet Service Provider gave you to connect. then configure the wireless settings and your done... if you still have problems, please feel free to contact me again..........
May 11, 2007 | 2wire (1000-400108-001) Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
