Question about LG Flatron W2286L 55.9 cm 22" LCD Monitor - 16:10 - 2 ms 1680 x 1050 - 16.7 Million Colours - 250 cd/m - 2,000,000:1 - DVI - HDMI - VGA - Glossy Black
How can i change fuse
My lg monitor screen is black. It powers on but no picture or light. What could be wrong?
    Problem Solver:
  • 18 Answers
The problem is most likely it burned out back light. If your screen turns on but you can't ever see anything on it, it is the back light that is not working. You can possibly fix it depending on the exact model, however, it is usually cheaper just to buy a new one.
Posted on Dec 16, 2014
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: hi everyone , ive got a LG Flatron monitor model
Check out for bad caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 15, 2010
  • 34 Answers
SOURCE: Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Posted on Aug 24, 2010
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
Several things, it could just be turned down real low but most likely it is not getting a signal from the source. What color is the light on the bottom. If it is not green you have an input signal problem.
Aug 13, 2014 | LG 22" FLATRON LCD Monitor
Monitor comes on and goes right to a black screen like the power was turned off but the power light is still green.
hi,
You have to check the back light of your lcd monitor. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
May 06, 2011 | LG Flatron L1511SK (Black) 15 in. Flat...
Hi everyone , ive got a LG Flatron monitor model number W1934S the problem im having with it is i keep getting a black screen with the power light still on, but if i unplug the monitor lead and plug in...
Jun 15, 2010 | LG W1934S-BN 19" Monitor
Black screen
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor keeps turning off but power says it's still on
You are OK with the power cord, more likely to be failure in the power supply/Inverter board, look for bad fuse and shorterd transistors, see Dell pictures here: http://s807.photobucket.com/home/budm/allalbums
Transistors should be checked out off circuits.
Mar 16, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
LG W2234S screen just went black
If you plugged power cable, and Power button on monitor is not working, something's wrong with the eletronics. Go for a refund.
Jan 15, 2009 | LG L1932TQ LCD Monitor
LG Flatron W2286L 55.9 cm 22" LCD Monitor - 16:10 - 2 ms 1680 x 1050 - 16.7 Million Colours - 250 cd/m - 2,000,000:1 - DVI - HDMI - VGA - Glossy Black Logo
61 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
