Question about Canon PIXMA iP3000 InkJet Photo Printer
My Canon iP3000 printer just stopped working as if unplugged from mains.
It's not the mains lead, (substituted).
  • Canon Master
  • 5,568 Answers
As with most modern electronics, your unit has a 'switched-mode' power supply and most are built well enough to outlast the warranty.
They are very efficient but the kind of service some parts (especially electrolytic capacitors) are subjected to adverse conditions.
If you want to try a DIY analysis, remove the housing from your unit and locate the power supply; if it is modular, you may have to open a second case (much smaller).
Power supplies are easy to identify since they are clearly a different animal than found on the main boards, being made up of coils and larger semiconductors than the other functions.
If you gain access, look for cylindrical components mounted perpendicular to the circuit board with a plastic foil jacket and an exposed aluminum top, there may be a lot of different sizes but these are the most likely failures.
Since they can burst when failing, the aluminum is scored in a 'Y' pattern to enable a more gentle bursting.
Check them closely and look for domed (bulging) tops. These are close to dying and typically no longer able to function as designed.
They vary in quality so replacements can be better (longer-lived) or worse.
Most techs will know which replacements are best and the cost difference is low and negligible.
Good luck-
Posted on Dec 29, 2014
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Printhead is not recognizing the ink cartridges
Canon IP3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All The Best Pineworks
Dec 29, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer won't turn on...is plugged in and has been printing well.
hi, have you tried checking, changing the fuse in the plug.
check the lead is fitted correct.
as for the fuse is the printer running of mains lead or just of the usb lead let me know, if its mains the unplug the lead that goes to your comp and then try it with just the power lead plugged in to see if that makes the differance.
Check the mains lead works try it on something else if you can if its running off only the usb lead then the lead may be at fault.
Let me know then i can assist you further ok
Nov 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixmar iP3000
the yellow light means you need to resume printing, hit the button on top right
Jun 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Since replacing 2 ink cartrides the printer doesn't work. The on/off light is flashing yellow
Have you tried unplugging the power cord from the back of the printer waiting a few seconds and plugging it back in. This may help it recognize the cartridges.
Apr 24, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
No power
check your adapter power is ok
check with other power adapter
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
How to check the PSU for IP3000 printer
I've just checked mine as it suddenly stopped working - does not even light up the green button.
I'm getting 8 volts Red to Black and 23 volts Red to Yellow so I guess it's fubared?
Dec 04, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
82 people viewed this question
old marine
old marine
