Question about Craftsman Garden
Craftsman lt 2000 muffler gets red hot an rund bad help pls
Took ohv cover of just looking all looks good I'm stuck
    Scholar:
  • 159 Answers
Governor for the carburetor . Remove the nut from the top of the air breather. Remove the air filter. Place them where they are not going to get too dirty. Remove the spark plug wire and the spark plug. Smell of threads if strong smell of fuel . Set aside for a while. Looking down into the carburetor move the throttle cable lever. If you can see the choke open and close freely .check the spark plug gap. Should be .040 reinstall spark plug. Looking at the side of the carburetor the will be a screw with a little rod that is going to the engine. There's a small plate attached to another rod see if it moves free if so go back to the screw adjust it in til stops. Don't try forcing the screw past it's stopping point them loosen the same screw 3/4 turn. That's it. Starting the engine it should run smoothly if not replace the spark plug.
Posted on Dec 12, 2014
18hp ohv cuts out after it gets warm or hot like it is running out of gas
I have a 12.5 hp Briggs & Stratton on a Murray that did that. The carburator is right above the muffler and when I replaced the muffler, I didn't put the heat shield between the muffler and carburator back on. The added heat from the muffler was vaporizing the gas in the carburator where the engine would no longer run once it got hot. Replacing my heat shield and putting a longer pipe on the muffler to get it away from the carburator solved my problem.
Aug 05, 2013 | Craftsman Garden
Poulan Leaf Blower red hot muffler
you need to turn the Hi screw on the carb in 1/4 of a turn.
Jul 22, 2013 | Poulan Garden
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
17hp kohler ohv runs rough and muffler glows red hot
muffler full of carbon remove muffler heat up red hot throw in bucket of cold water remove and throw as hard as you can on pavement clean carbon out of exhaust part of headt make sure piston is all the way up you dont want carbon in your motor reinstall thank me
Oct 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Where to find the spark pug on my 21inch 139cc mtd ohv lawn mower
It should be under a rubber boot between the valve cover *(stamped OHV or OHC) and the muffler.
Good luck and be careful. Dont pull that boot when the engine is hot!
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Could someone tell me how to remove the muffler on a Craftsman 25cc weedwacker?
Look at the plastic cover that covers the muffler. There is probably something that you have to depress to remove it. Once removed you should be able to see the bolts that hold the muffler on.
Jul 31, 2009 | Craftsman 25cc Gas Line Trimmer
18hp/ohv craftsman 42in wont crank
One thing to check, see if there is a piece of root stuck under the tractor there is interrupting any of the security features from allowing the tractor to start. It might be a small piece that stops a plunger from engaging.
Mar 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
71 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
