Red lamp light comes on and TV turns off model # WD 60735 what's the reset procedure but it shows a good picture after a few minutes it turns off
    Scholar:
  • 159 Answers
With the remote control in your hand press the power button to turn it on. Hit menu check sleep settings some one might have accidentally hit the timer .set it to 00 clear it.
Posted on Dec 12, 2014
ladywinn
  • 5138 Answers
SOURCE: wd 60735 the tv turns on but in 30 sec turns off
No, just replace the Lamp but make sure the Lamp Fan is OK first.
Posted on Dec 27, 2009
  • 26 Answers
SOURCE: Mitsubishi wd-60735 no picture and red lamp light
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Posted on Oct 07, 2011
SD Tech
  • 14553 Answers
SOURCE: Turn Tv on (Model WD-60735) and I get sound but no picture. Then after a few seconds it turns itself off and the STATUS light stays a solid Red. I have unplugged and
Have you check and or replaced the lamp in this set?
Posted on Mar 21, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WD 65733 TV. Red lamp light comes on after picture appears on screen.
Check this possible answer I provided and it worked for another similar set:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on May 23, 2012
  • 49 Answers
SOURCE: mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Posted on Jul 17, 2012
Tv comes on with picture and then shuts down to red blinking light
It will be the LAMP the only last between 5,000 to 8,000 playing hours so if your not watching TV turn it off.
Jun 03, 2015 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd 60735 dlp tv red lamp light
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd-60735 no picture and red lamp light stays on
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
Just replaced the bulb in a wd-60735 and there is no picture and no sound the tv turns on and 20 seconds cuts out the status indicator stays red
hello make sure you've fitted lamp securely and the lamp cover as well this will be down to the safety switches hope it helps
regards
shaun
Dec 06, 2010 | Mitsubishi WD-60735 Projection Television
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
