Question about Toyota Genuine grill year to Voxy system 60
How do I open passenger sliding door for a toyota voxy. no clue, please held.
SOURCE: Rear Door Handle Broken
I had the same problem, and here is the solution:
http://www.findonefindall.com/toyota-sienna/siennareardoor.htm
It includes step-by-step instructions and photos. I printed it and headed to the garage. I while later (hours actually) it was fixed. I did end up going to the hardware store and buying the EXACT size screw they recommend. I went with a screw rather than a nut and bolt. Worked fine.
Posted on Dec 26, 2008
SOURCE: 2005 Toyota Sienna Sliding Door Won't Open
Have 2005 Sienna and its Driver side door was not openning. Cheap dealer fixed it himself in front of me. After opening the doors plastic assembly while sitting inside with a screw driver. Then he bent the clip towards left where the metal wire is connected. If you guys want to see what he did i would record a video and upload for you guys. Let me know at xahid2000@yahoo.com
Posted on Mar 13, 2009
  • 1861 Answers
SOURCE: 2005 Toyota Sienna sliding door problem
You have a sticking fuel door lock-device. Look to see if the tab is in the down position.
Posted on Jun 09, 2009
  • 34 Answers
SOURCE: both manual sliding doors on my Toyota Sienna will not open
If you can remove the inner door panel you will see a maze of cables running to the various locking points on the sliding door. If the cable going to the FRONT latch on the sliding door is broken (or in my case, simply dislodged inside the door) the door acts as if it is frozen shut.
The front cable is short, and easily replaced even by a newbie mechanic.
Posted on Aug 11, 2009
  • 141 Answers
SOURCE: the sliding door on my 2004 toyota sienna won't close
Try this.....Find the latch on the door, stick your finger in the hole, lift up and pull the door handle at the same time, the inside latch mechanism should go up, then try the door again. It would be nice if that's all it was huh? Sometimes they stick when they get too cold. If this works for you....spray it with some WD-40 or graphite. Hope this worked for you. Cheaper than the 2000.00 motor!
Bryon
Posted on Feb 05, 2010
How many litres of oil for toyota voxy 1.998 engine capacity
How many litres of oil for toyota voxy 2.0 engine Kufa, 4.2L of oil with a filter or 4.0L without filter change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Toyota VOXY Solving Car Problems
Toyota Noah Voxy 2001 2007 Guide to repair and maintenance Page 4 Catalog...
http://autorepman.com/en/toyota/3422-toyota-noah-voxy-2001-2007-engine-repair-manual.html
Mar 24, 2016 | Toyota Cars & Trucks
Electric sliding passenger door of Toyota Raum won't open when front door is closed either by pulling handle or pushing switch on dashboard.
Although the attached video is for a Toyota Sienna, the basic troubleshooting and repair is somewhat the same...and one-way this d.i.y. chose to tackle the problem himself. I do recommend purchasing or downloading a service repair manual specific to your vehicle for added tech support and will be a helpful resource should other mechanical issues arise.
Toyota Sienna Power Sliding Door Repair
Jun 03, 2014 | 2012 Toyota Prius v
Why does my 2006 toyota sienna power sliding door not close properly
Could be resistance in one of the tracks, or the motor.
If the motor hits a resistance the door opens in case the resistance is a human.
Jan 13, 2013 | 2006 Toyota Sienna
Our passenger side power sliding door doesn't open
Check out the wiring. Sounds like something is loose or the switch may be going bad.
Mar 10, 2010 | 2004 Toyota Sienna
Cabin filter
1 Tools needed are a Phillips screwdriver and a socket wrench. Open door to passenger side of vehicle. 2 Under the glove compartment is a kick plate cover held in place by four screws. Remove the screws and take off cover. 3 The door to the cabin filter is now visible. Remove screw in door and unhinge. 4 Remove the first filter by pulling straight down. Remove the second filter by sliding forward and pulling down. Replace with clean cabin filters. Reattach door and kick plate cover.
Good luck and hope this helps.
Jun 26, 2009 | 2004 Toyota Avalon
Driver side window inching up to close and completely stuck now
just remove the door panel its pretty simple once you are in door panel you will see the motor.the door panel is held on by either screws or plastic push ins..there little plastiv pins that expand after they are in hole
Jun 17, 2009 | 2000 Toyota Sienna
Both manual sliding doors on my Toyota Sienna will not open
Check out this youtube video for taking off the interior door panel and resetting. https://www.youtube.com/watch?v=MkC2OiOiE_U
Apr 09, 2017 | 2000 Toyota Sienna
Sienna sliding door hinge replacement
I have exactly this problem on my 2004 toyota sienna. Just started happening and the door now rubs the edge of the rear quarter panel as the door opens and closes. Any help on how to replace the middle hinge would be appreciated.
Apr 09, 2009 | 2006 Toyota Sienna
Toyota Genuine grill year to Voxy system 60 Logo
616 people viewed this question
Top Toyota Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Toyota Retail Supply Expert? Answer questions, earn points and help others
