Question about Swiss Legend Watches
How do I set the day?
Trimix driver 412122558
Police 14383JS-03 Mens Driver Blue Chronograph Watch
Try Googling (police)(14383JS-03)(manual) without parens.
Feb 26, 2018 | Police Watches
How can I change the days in casio Ef 331
First of all avoid setting the day and day of the week between 9.00 pm and 6.00 am. The day and day of the week may not change in the following day if you do.
Try this,
1) Pull the crown to the first click.
2) Set the day by rotating the crown counterclockwise.
3) Set the day of the week by rotating the crown clockwise.
4) Push the crown back to its normal position.
Hope this will help.
Cheers
May 16, 2016 | Casio Watches
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 | Watches
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Apr 14, 2009 | Seiko SGF204 Wrist Watch
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Setting the day and date
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
Nov 22, 2007 | Rolex Day-Date President 118238 Wristwatch
Watches Logo
37 people viewed this question
Top Swiss Legend Watches Experts
ray gallant
deton8 von Splosion
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
