Question about Yamaha Music
No sound from foot pedals on my hs8 yamaha organ
  • 20 Answers
Input Connector is damaged.
Posted on Dec 23, 2014
2 Suggested Answers
pianokey54
SOURCE: I have a yamaha electone hs4, The foot pedals do not work.
JM: Your problem is this: There are rubber washerson the bolt that holds the pedal on. They are shot. Most likely Yamaha doesnot have the parts.Go to the plumbing dept of a hardware store and get some faucet washers and replace them. YYou can tell if the washers are shot by tiping over the organ and looking at the pivot bolt. Most likely that is yoiur problem. I am an organ tech. and have replaced many of these. DM
Posted on Mar 16, 2009
I have just got my grandmothers Yamaha B-4CR organ there is low volume coming out but when I move the vplume pedal it doesnt increase the sound... What can I do
As I recall, the volume pedal on that model is optically coupled, meaning it operates via a light source. I'm afraid it will probably need a tech to come check it out. You can find on close to you by calling your nearest piano/organ store, or by going to the MITA tech site which has a search engine. Here's the link-
http://www.mita.com/
Jul 22, 2016 | Yamaha Music
All the foot pedals on my 1972 Yamaha Electone D-7 from 'A flat' down sound like 'A flat'. What's happened?
That sounds like a problem with the contacts in the pedalboard or a short in the wiring harness. I'd suggest calling a tech in. You could cause a bigger problem if you aren't experienced.
Feb 05, 2016 | Yamaha Music
How can I turn off the sound to the foot pedals of my Lowery organ. Is there any setting on the organ to do that?
If you turn off any voice tabs for the pedals, they are effectivly turned off.
Mar 22, 2015 | Music
Have a hs8 yamaha organ no sound from base pedals.
Check the cable connection. Replace the midi cable if necessary
Dec 12, 2014 | Yamaha Music
Organ repair
Yamaha electone organ have no sound el 25 need help thnks...
Sep 03, 2013 | Yamaha Music
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
No sound from Yamaha Electone HS-6
First check if you get sound from the headphone jack.
Do you hear anything as the power comes on from the speakers..? A slight bump?
A lot of these dead audio things can be traced to a failure at the expression pedal. often these use a light dependent resistor and the illuminating lamp burns out. This is all down by the pedal.
Many of the Yamaha organs, including the FX20 I have, have circuitry that checks that the power amp has DC balance before a relay closes to connect the speaker. A failure in the amp can cause dead sound as well.
Jan 12, 2010 | Yamaha Music
Yamaha electone organ no sound-
Check if you may have knocked off the speaker leads OR ones to an expression pedal.
Sep 16, 2009 | Boss Micro BR Digital Recorder
Mar 13, 2009 | Yamaha Full-Size Keyboard
Music Logo
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
