Question about Lands Phones
New cordless phone showing out of range
Changed batteries and initial charging for 16 hrs
    Filmmaker:
    Uploaded 5 video answers.
  • 52 Answers
Check that it is registered with the base station and check the range coverage. If you are not out of area of coverage and handset is properly registered to base station then your handset may be faulty.
Posted on Dec 13, 2014
SOURCE: Motorola Cordless MD400 series - "Out of Range" message on display
change the batteries in the base unit, base unit takes 4 AAA battries
Posted on Jan 27, 2008
  • 103 Answers
SOURCE: charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Posted on Feb 04, 2008
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Posted on Jul 06, 2008
SOURCE: UNIDEN Powermax5.8 cordless phone charging
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Posted on Jul 30, 2008
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
Bluetooth H520. Why has it been charging(initial charge) for 16 hrs and still flashes red?
Initial charge usually takes longer, but 16 hrs sounds long. Try charging at another outlet port or try another wire.
Mar 05, 2016 | Motorola Radio Communications
Out of range At times when I am on the phone, it cuts out and shows "out of range" in the window
Joan, there are two things that can cause this,one, the batteries are not holding charge anymore or your base is loosing signal based on its location relative to handset.
Replace batteries and then charge them for 5 hrs before initial use. You can purchase replacement batteries from your local radio shack or walmart. Please bring your handset with your for the store to find exact replacement.
Nov 01, 2011 | Uniden Cordless Phone
Uniden EXP370, un pluged to paint; after no base to phone contact; can not get dial cone
You have lost registration due to battery lossing charge. This is the sign of your phone battery going bad. I would suggest you purchase new batteries and then charge the for 5-7 hrs initially.One you have fully charged batteries you can register the handset to the base.
Sep 23, 2011 | Uniden Cordless Phone exai398i
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
3month old battery does not charge full even after ten /more hrs.
i could charge to full by usv port in 16 hrs. now i do not let discharge more than 20% or chage every 10hrs.
ravi shanker malviya
Jan 18, 2009 | Sony Ericsson P990i Cellular Phone
Charge/in use light
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Out of Range
Make certain that the phone line cable is plugged securely into the base unit in the back. Disconnect it and re-insert it into the connector firmly. That should do it if the battery pack has been sufficiently charged.....12-16 hours should do it for the initial charge. Of course, you can't ecxpect it to find the base unit if it is 2 miles away, under a metal box! Just kidding!!
Dec 28, 2007 | GE 28112EE2 Cordless Phone
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
