Question about Fisher and Paykel Refrigerators
When we open the doors Fridge or Freezer the alarm beeps twice and the light flashes Red and Green but when it Flashes green the level indicator shows lower then what the temp is set at. Does anyone k
Fisher & Paykel - Active Smart - Fridge on top freezer on the bottom The unit is about Four Years old
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
You may need technican to come out with his laptop an recify the problem it will also detect anyother faults as well.
Posted on Jan 17, 2016
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: Problem with Fisher & Paykel
so both the freezer and the frigerator are both warm then? If this is the case then you can try to remove the rear panel down where the compressor is leave machine off for about ten minutes then plug the machine back in there isa small box like unit or relay on the side of the compressor if your hearing it click on and off or if you disconnect the wires going to it and shake it lightly to hear if something is rattleing on the inside also if you have a multimeter and a pair of needle nose you can do this to test the relay
Remove the cover on the compressor relay box. The cover is usually held in place by retaining clips or tension clips. There are usually three components inside this box: the compressor relay, the compressor motor terminals and the overload protector. The compressor relay is the largest component and will either be wirewound or solid state. If the part is solid state, then you will have to have a professional test the part, as it requires specific equipment for testing. If you have a wirewound relay, pull it straight off of the compressor.
  • 5
    Use a pair of needlenose pliers to pull the connector off of the relay's terminal. Be sure to pull it off by grasping the connector and NOT the wire. Check both the wire connector and the compressor relay for any signs of corrosion.
  • 6
    After you dust the relay off, take a good look at it. You should see two plug-type terminals marked "S" and "M" and the slip-on terminal marked "L." Set your multitester to read ohms (usually the X1 or RX1 setting). Set the relay on a flat surface so that the "S" and "M" terminals are on the bottom.
  • 7
    Insert one probe of your tester into the "S" terminal and one in the "M" terminal. Your tester should have a reading of "zero" ohms. Keeping the probes inserted in the terminals, turn the relay over. You should hear an audible "click" and the tester's reading should change from "zero" to "infinity."
  • 8
    Turn the relay back over. Now, touch one probe to the "S" terminal and the other probe to the "L" terminal. The tester should read "zero" ohms. Turn it over again with the probes still on the terminals and the tester should read "infinity."
  • 9
    Turn the relay back over. Now, touch one probe to the "M" terminal and the other to the "L" terminal. The tester should read "zero" ohms. Turn the relay over with the probes still in place and the tester's reading should not change -- it will remain at zero ohms.
  • 10
    If your compressor relay passes this series of tests, then your relay is not the problem with your refrigerator. If it fails any one of these tests, then take it to an appliance parts shop and purchase a replacement. Replace everything back in its original position and be sure to remove the 20-ohm resistor from the capacitor before plugging the refrigerator back in.
  • note if you are unable to perform these tests please call a technician if you have any further questions please message me back as well as please remember to rate how this opinion has helped in your appliance repair all in all if your machine is warm its either the relay or the compressor Thanks again
  • Rick
  • Posted on Dec 02, 2010
    Model E402b. Why is the alarm going off?
    Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
    Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
    Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
    Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
    ·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
    Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
    Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
    Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
    Jun 02, 2015 | Fisher and Paykel Refrigerators
    Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
    check the thermostat setting for the compartment
    it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
    some fridges have a system whereby if the door is open too long then it notifies the user to close the door
    May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
    Open door 18 beeps lights flash red green fridge not cooling
    Mar 14, 2015 | Refrigerators
    My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
    Some appliances malfunction can be displayed in hexadecimal or in binary code.
    So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
    For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
    " E20 " means "No drain water"
    " E10 " means "No fill up water"
    Dado
    Sep 08, 2014 | Zanussi Washing Machines
    Beeping alarm every 6 hours like most posts here, top of fridge not getting cold enough10C ... but
    beeping alarm every 6 hours like most
    posts here top of frigde not getting cold
    enough10...but
    Jul 13, 2013 | Fisher and Paykel Active Smart E522B...
    Servis Fridge Freezer Model # M7973B-I/1 light flashing
    Likely problem is the temperature setting control is failing.
    Apr 04, 2012 | Refrigerators
    Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
    Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
    Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
    Ps3 wont stay on
    charge it red light turning of and beeping is meaning its dead
    Mar 02, 2010 | Sony Playstation 3 (PS3) Console
    Dashboard light flashes small red car on left hand side but it doesn't stay on long enough.what is that
    this is the factory alarm indicator light. try locking the doors while your in the car and wait a few minutes. Unlock the door and open it and the horn should start to beep. Put your key in the driver's door and turn twice to unlock all the doors and stop the alarm.
    Apr 21, 2009 | 2001 Dodge Intrepid
    How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
    Step 1 - To reset your Bluetooth headset:
    1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
    2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
    Step 2 - To pair the headset with your phone:
    1. Make sure the headset is turned off.
    2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
    3. Place the phone within 20 cm (8 inches) from the headset.
    4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
    5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
    6. The headset beeps and flashes green when successfully paired.
    Jan 21, 2009 | Audio Players & Recorders
    Refrigerators Logo
    167 people viewed this question
    Top Fisher and Paykel Refrigerators Experts
    Brian Coughlan
    John Tripp
    John Tripp
    Colin Stickland
    Colin Stickland
    Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
